mserge Schrauber
Joined: 06/20/2005 Posts: 923 Karma: +6 / -0 Location: Luxemburg
01-12-2005, 11:16 Subject: A3 Coolant Warning Light: Meaning & Fix |
Hello.
Eine Freundin von mir hat ein A3 1,9 Tdi PD 74 KW (AXR). Nach dem Starten leuchtet während +/- 30sec im FIS die rote Alarmleuchte für Kühlwasser (Überhitzung). Danach geht sie dann aus und es ist alles normal während des ganzen Tages. Ich dachte dann an den zweiteiligen Temp-Fühler und tauschte den dann, leider ohne Resultat, ausser dass er jetzt, nach mehrstündigem stehen, auch während par Sekunden leuchtet, dann aus geht. Die Temp-Anzeige funzt wie gehabt richtig (90°C). WassThe first one is okay.
Does anyone have any ideas on how I can further test and measure this?
Can a VAG diagnostic tool be used to perform a diagnosis (even if there are no error codes in the fault memory)?
Thank you for all the information. A4 Avant 2,5 tdi 110kw; AFB; BJ2000
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 13-09-2026, 11:48.
01-12-2005, 11:22 Subject: A3 Coolant Warning Light: Meaning & Fix |
In your coolant reservoir, there are likely two sensors that are not detecting enough water due to the coolant's conductivity. The coolant itself is slightly conductive.
Try cleaning the two pens with a toothbrush to remove any residue that might be causing them to not work properly.
It might also be a good idea to change the coolant occasionally, especially if there's a buildup of deposits.
Unfortunately, VAG-COM cannot currently detect the coating on the pins, perhaps in a later release with image processing and a Robo-Cam  .
Translated on 13-09-2026, 11:50.
Profile PM WWW Garage |
01-12-2005, 12:12 Subject: A3 Coolant Warning Light: Meaning & Fix |
Rainer K. wrote: | VAG-COM unfortunately cannot recognize the coating on the pins, perhaps in a later release with image processing and a Robo-Cam  | .
Hi Rainer,
When can we expect this release?  Gruß Ulf
Translated on 13-09-2026, 11:51.
Profile PM Garage |
mserge Schrauber
01-12-2005, 13:34 Subject: A3 Coolant Warning Light: Meaning & Fix |
Hello Rainer and Ulf,
I don't know why you're making fun of me, but I still want to thank Rainer, and I will be testing this out over the weekend.
Regarding my question about the VAG-***, I was thinking more about reading the values of the sensors or testing the engine control unit (ECU), but first, I'll start with the simpler things as Rainer described.
Thank you again. A4 Avant 2,5 tdi 110kw; AFB; BJ2000
Translated on 13-09-2026, 11:52.
01-12-2005, 14:04 Subject: A3 Coolant Warning Light: Meaning & Fix |
Come on, there has to be some fun.  Possibly, there is a measurement block where a corresponding resistance value is displayed, but I'm not sure about that.
mserge Schrauber
09-12-2005, 9:13 Subject: A3 Coolant Warning Light: Meaning & Fix |
Okay, I have to say, "Respect!"
Last Saturday, as described here, I cleaned the two sensors in the water reservoir with a toothbrush (as best as I could). Afterwards, I rinsed the reservoir with water and refilled it with a G12 mixture. Fortunately, the light hasn't come back on since then!
Translated on 13-09-2026, 11:53.
