Used MSG, No PIN (WFSIII)
mummelratz
Post18-01-2006, 15:19    Subject: Used MSG, No PIN (WFSIII) Quote
How do you activate that in the vehicle? Is there a kind of master PIN to get the device to start working?
Translated on 09-09-2026, 7:19.
Ross-Tech-Support
Post18-01-2006, 15:32    Subject: Used MSG, No PIN: Troubleshooting & Solutions Quote
mummelratz wrote:
How can one put that into operation in the vehicle?
a) Retrieve PIN from the merchant (via fax inquiry).
b) Read out the EDC15/16 module and, in this way, determine the PIN.
c) Use a compatible diagnostic tool to read the engine control unit and, in this way, determine the PIN.
Those are some of the options that would be suitable for the average user...
mummelratz wrote:
Is there a kind of master PIN to convince the device to start working?
No, then we could just skip the whole WFS thing.
Translated on 09-09-2026, 7:20.
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Brake Fluid MIL: No Function Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WFS Code: Definition and Examples On-Board Diagnostics (OBD)
No new posts Climatronic Problems: Codes 4F8 & 4B6 Explained On-Board Diagnostics (OBD)
No new posts ECU Login Code: How to Find & Use On-Board Diagnostics (OBD)
No new posts Scratch-off code on keychain Diesel Engine Technology
