CAN Hardware, CAN Software, CAN Protocols - CAN-Bus Forum for your CAN-Bus project. CAN-Bus and Electronics.
Turbo gear ESC EVP
New Topic Reply 🔗 🖨 Dieselschrauber - Overview » On-Board Diagnostics (OBD)
gfahrer
Forum member since: 28.01.2006
Karma: +0 / -0   Thank you, like!
Post28-01-2006, 23:14    Title: Turbo gear ESC EVP Quote
Good evening everyone,
Since I am not a professional, but try to understand things with expertise because the workshop hasn't been able to do it yet, here is my task:
For the G300 td, manufactured in 8/96, with engine type 606.
Here's what happens: After starting, the ESC light illuminates, and then the Bolide runs, but without turbo (the turbo doesn't engage).
Sometimes the EVP light still illuminates, but the speedometer doesn't work, and the automatic system doesn't function. However, I can "push through" this error so that the functions can run again.
Error reading was unsuccessful at my (Chrysler)Daimler workshop.
Okay, I'm curious to see what you come up with.
