O2 Sensor for V6 TDI 3.0/2.7: Which one?
bafische
Karma: +22 / -0   Thank you, like it!
Post01-02-2006, 13:04    Subject: O2 Sensor for V6 TDI 3.0/2.7: Which one? Quote
Which Bosch oxygen sensor is installed in the current AUDI V6 TDI 3.0 or 2.7L engines after the turbocharger (engine codes: BMK/BNG/BPP/BSG)?
Bosch LSU 4.2 or 4.9?
Part number is 057 906 202 or 059 906 202 F.
Thank you for your help.
Best regards, Bavarian.
"Luft und Menge müssen stimmen - der Rest ist Physik."
unumstössliches Gesetz in der Dieselmotorenentwicklung
Translated on 04-09-2026, 4:16.
No new posts Lambda Values: Definition & Regulations Technical Articles
No new posts P0170 - Fuel Mixture Control (Oxygen Sensor Circuit Malfu... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 3.0 TDI Problems: Lambda Sensor/Oxygen Sensor Diesel Engine Technology
No new posts Linear Lambda Sensor: What You Need to Know On-Board Diagnostics (OBD)
No new posts Audi A2 8Z AUA Engine Lambda Sensor Gasoline Engine Technology
No new posts 1.4 TDI: Faulty EGR Valve & O2 Sensor? Diesel Engine Technology
