Lambda Sensor Error
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
PatB4
Post12-02-2006, 13:41    Subject: Lambda Sensor Error Quote
Hello!
I own an Audi 80 (B4) built in 1993 with a 2-liter gasoline engine (Engine Code: ABK (115 horsepower Digifant)). Mileage: 172,000 km.
I was now able to pinpoint the problem:
If I drive 10 km on country roads after a cold start, the engine runs perfectly (water temperature around 50°C). However, if I drive in city traffic, where the engine heats up quickly, the power suddenly disappears. The RPM remains approximately the same. Without load, I can rev the engine up. When I engage the clutch again, the same thing happens. The engine doesn't stutter or run unevenly - the idle is also fine; it's just that there's no more power (it feels like the car is being braked).
I had the fault memory read out at VAG:
00525 028
Lambda Probe G39
Short circuit after plus
Does anyone recognize this error message?
How can I check the connection lines or where do they run in this vehicle?
and how do I change the L-probe on this vehicle?
Thank you for your help,
Best regards, Patrick
No new posts Seat Ibiza 6L error code 16415 - Bank 1, Sensor 1; Heater... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0420 Error: Lambda Sensor/Catalytic Converter Issue Gasoline Engine Technology
No new posts BBY Error 17584 Lambda Sensor after Catalytic Converter Gasoline Engine Technology
No new posts Lambda-Sonde (G39)- Kurzschluß nach Plus On-Board Diagnostics (OBD)
No new posts Idee : 10cent Tuning durch nachgerüstete Lambda-Sonde re... Diesel Engine Technology
