00550 Injection start control, setpoint difference.
Possible cause of error: -> Injection start not functioning correctly. -> Possible consequences: -> Lack of power at higher speeds and/or difficulty starting the engine. -> Troubleshooting: -> Check and adjust the injection timing.
Possible cause of error: -> Injection pump adjustment range blocked (dirt, debris). Possible consequences: -> Reduced power at higher engine speeds. Troubleshooting: -> Check the fuel injection system.
Possible cause of error: -> Fuel supply interrupted: fuel tank empty, fuel line or filter clogged, system drawing air. Possible consequences: -> Possibly error code 00542: implausible signal from needle lift sensor. Troubleshooting: -> Check the fuel system.
Possible cause of error: -> Engine was stalled (within the last 50 starts).
Troubleshooting: -> Clear the error memory and continue to monitor the vehicle.
Possible cause of error: -> Wiring fault to the injection start valve (N108) - Possible consequences: Engine misfires at idle because the injection start timing is constantly set to 'early.' Possibly multiple errors are stored. Troubleshooting: -> Check the N108 valve, -> Check the fuse.
Possible cause of error: -> N108 injection timing valve worn out. Possible consequences: -> Inability to maintain a consistent injection timing at the 'basic setting' (display field 2 fluctuates more than 10 units) - uneven engine running, lack of power. Troubleshooting: -> Replace the N108 injection timing valve.
