Error code on 1.9 TDI AFN engine - Strange error!
randy
Post22-03-2006, 21:37    Subject: Error code on 1.9 TDI AFN engine - Strange error! Quote
Hello to all you tech freaks icon_biggrin.gif.
I'm having a small problem with my...
A4 B5 1.9 TDI AFN 110 hp.
-no chip, if suspected-
Now I'm having problems with something that's happening under...
The performance seems to be dropping off slightly.
'Hey, I'm driving on the highway at 160 km/h.'
and I have to brake - the acceleration.
It takes forever afterward... also, it speeds up.
The performance drops when going uphill.
Not too long ago, I had already...
'Lack of power, but the mass airflow sensor (MAF) was replaced there.'
And then everything was working again.
Now I've borrowed an OBD2 interface, and with...
retrieve the engine fault memory in an English VAG-COM 3 demo.
selected, and the following can be found there:
VAG-COM Version: Release 311.2-N.
Control Module Part Number: 028 906 021 CE
Component and/or Version: 1.9L R4 EDC 00SG 0803
Software Coding: 00002
Workshop Code: WSC 06325
1 Fault Found:
00550 - Start of Injection Control.
17-10 - Control Difference - Intermittent
Can anyone possibly help me with this?
I am grateful for any advice.
Wishing everyone a lovely evening!
Hello.
Translated on 14-07-2026, 11:29.
Rudi
Post22-03-2006, 22:24    Subject: Error code on 1.9 TDI AFN engine - Strange error! Quote
Tip: Search function icon_exclaim.gif icon_wink.gif.
'Spritzbeginn *550' provides something like this:
/viewtopic.php?t=11776&highlight=start_of_spray + *550
'lg' translates to 'best regards' or 'kindly regards' in English. It is a common abbreviation used at the end of emails and letters.
Translated on 14-07-2026, 11:32.
No new posts Doku Caddy 9K9, MJ 98/99, Motor geht aus, Fehlercode 1268 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P068A Error: Engine Won't Start (Relay J271) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document error 00575 with full throttle, AKN and AFB engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Steering Wheel Error: Funny Bug in Address 16? On-Board Diagnostics (OBD)
No new posts Fehlercode 18150 - A4 8E2 Motor ALT mit Multitronic On-Board Diagnostics (OBD)
No new posts Engine Misfire: Troubleshooting & Error Codes On-Board Diagnostics (OBD)
No new posts Error code: 001618 on T5 1.9 TDI, engine code: BRS On-Board Diagnostics (OBD)
