I have this T4 van that I got from my uncle.
It's a 1.9 diesel engine with 68 horsepower.
"For the past few days, it's been difficult to insert the tubes. It happened quite suddenly..."
The car has 230,000 kilometers on the odometer; I'd guess the clutch is worn out.
My question is now: Will the clutch from a 1Z engine fit into a T4 bus?
Because I still have one lying around, and it should be significantly more stable.
If it doesn't fit, do you need to replace both the pressure plate and the clutch disc, or is replacing just the clutch disc sufficient?
The release bearing should only be accessible from the inside, right? Unfortunately, I can't check because my laptop just crashed and I can't access the instructions at the moment...
Sure, no problem! Here's the translation:
"Thank you in advance!" Man muss es nicht brauchen, aber man muss es haben!
Translated on 15-08-2026, 2:18.
