TDI 90 PS: Power Loss Troubleshooting
Goodspeed48
Post09-04-2006, 18:21    Subject: TDI 90 PS: Power Loss Troubleshooting Quote
I urgently need your expert advice.
I had the head gasket replaced on my Golf III TDI 90 hp, and while they were at it, they also replaced the turbocharger (original turbocharger, with approximately 50,000 km on it).
"When I'm driving on the highway and accelerate, the engine suddenly loses power at 140 km/h and around 2900 rpm. It then doesn't pull at all. The same thing happens at 160 km/h and 180 km/h. The same issue also occurs when I'm driving uphill on a country road, but then it happens at around 120 km/h."
I don't think it's the charger. I drove with the old charger for two weeks after replacing the head gasket, and I had the same problem.
There was also an entry in the error memory, but I don't remember the exact details. I think it might have been something related to the diesel pressure - could that be it?
I can have it checked again on Monday if that's important for the diagnosis, but the symptoms might already provide some clues.
Thank you for your help!!!
Goodspeed.
Translated on 25-09-2026, 3:38.
Post09-04-2006, 18:53    Subject: TDI 90 PS: Power Loss Troubleshooting Quote
The exact description of the error in the engine control unit would be important. Please have it read out again.
Is that a 1Z engine?
Translated on 25-09-2026, 3:39.
Goodspeed48
Post09-04-2006, 19:02    Subject: TDI 90 PS: Power Loss Troubleshooting Quote
Greetings, Rainer
Hi Rainer,
Great, thanks for your help.
Okay, then I'll have to get it re-examined.
Can you say anything about it in advance?
I just checked again - there seems to be something wrong with the diesel pressure.
"vg"
This is a common abbreviation for "very good" in German. It is often used in online forums and chat rooms.
nino
Translated on 25-09-2026, 3:41.
Post09-04-2006, 19:55    Subject: TDI 90 PS: Power Loss Troubleshooting Quote
Well, how about you start by checking the usual things first?
/newuser.php
Translated on 25-09-2026, 3:42.
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss AUY 85 kW: Causes & Solutions Diesel Engine Technology
No new posts G3 TDI: Power Loss Troubleshooting Diesel Engine Technology
No new posts Power loss and ABS Diesel Engine Technology
No new posts Performance Loss Above 130 km/h (AJM) Diesel Engine Technology
