Devilseye503 Guest
27-04-2006, 19:37 Subject: |
Even at idle, with the variable geometry turbine (VTG) vanes fully open, the turbocharger rotates; after all, the engine still produces some exhaust energy even at idle. Let's look at two numerical values: The turbocharger speed at idle is approximately 10,000 RPM with the VTG vanes open and approximately 30,000 RPM with the VTG vanes closed.
'That's true that it still rotates even with the VTG open - however, mine also presents a flow resistance of at least 40 mbar when cold (i.e., a value that causes it to drop below ambient pressure) - but when the engine is warm, it's 0. As for the speed, it might run at around 1000 RPM with the VTG open, but not much more.'
Translated on 15-08-2026, 3:05.
schneirk Schrauber
Joined: 09/13/2005 Posts: 57 Karma: +8 / -0 Location: Bad Salzuflen
28-04-2006, 10:06 Subject: |
Devilseye503 wrote: | Quote: | | It might run at approximately 1000 RPM with the open voltage, but not much more. |
... take your current value and multiply it by 10, then you'll have a more realistic valuation.
unless we're talking about chargers for electric commercial vehicles!
Regarding the issue of resistance again, because the charger is running, it offers only relatively low resistance. Some of the measured pressure drops can be attributed to the "vacuum effect"! |
Translated on 15-08-2026, 3:07.
Devilseye503 Guest
28-04-2006, 13:31 Subject: |
Probably not - I already looked at it myself when I was working on the ARL engine.
Zak1976
Joined: 03/09/2005 Posts: 225 Karma: +0 / -1 Location: Barendorf
28-04-2006, 20:14 Subject: |
Well, I can't quite imagine such a significant difference, even though ULF's explanation sounds logical.
How about an LDA (Leak Detection Analysis)? It should provide clarity regarding the pressure conditions and is definitely not a bad investment for the future.
I would rather consider the engine control unit (ECU) as the source of the problem, not the turbocharger.
Where are your measurements...?
How do you explain the different values of -40 mbar differential pressure with a cold engine versus 0 with a warm engine? Is this due to the viscosity of the oil, or the oil pressure (although it should be fully present after just a few seconds)? Or perhaps the variable turbo geometry (VTG) is controlled differently depending on the engine temperature? Fährt mit Golf 3 TDI Umbau (von AFN auf ARL)
Translated on 15-08-2026, 3:08.
Profile PM Email |
donalexo Profi-Schrauber
Joined: 01/08/2003 Posts: 695 Karma: +0 / -0 Location: Würzburg
29-04-2006, 18:27 Subject: |
@ZAK1976:
The difference can be explained by the different exhaust gas temperatures when the engine is warm and cold. The turbocharger is a machine that operates based on thermodynamics, utilizing the enthalpy difference, which means that the exhaust gases also come out at a lower temperature  .
Therefore, it's not just the pressure difference across the turbine wheel that matters, but also the auxiliary gas turbine (AGT) plays a role.
Alex. AUDI A3 1.9 TDI, EZ 12/96, ursprüglich MKB AGR, umgebaut zum AHF mit GT1749V-Lader, verkauft mit 250tkm
Touran 1.9 TDI, EZ 09/2004
Translated on 15-08-2026, 3:10.
