Abgasrückführung Regeldifferenz beim AAT
Corvetto
Post17-06-2006, 17:09    Subject: Quote
Hello everyone!
had recently encountered the following problem:
/viewtopic.php?p=85862#85862
...there were errors stored in memory....
550 Injection Start Control
519 Suction Tube Pressure Sensor
560 Exhaust Gas Recirculation
I just adjusted the ESP settings, and 550 and 519 are no longer present...
560 remains, and the symptoms are also...
Can someone help me?
Thank you!
Audi 100 C4, Bj 1993, MKB: AAT
christians
Post17-06-2006, 21:44    Subject: Quote
Replace the AGR valve gasket with a suitable metal sheet...
I am usually against it, but it is optimal for troubleshooting.
Gruß Christian
Corvetto
Post18-06-2006, 2:33    Subject: Quote
christians wrote:
Why don't you just temporarily replace the AGR seal with a suitable metal plate...?
I'm usually against it, but it's ideal for troubleshooting.
I've tried, but nothing seems to change...
The problem occurs when accelerating, and when coasting, regardless of whether it's at 50 or 160... as soon as the speed is maintained for a longer period, I no longer have enough power when I press the gas pedal.
Thank you.
No new posts P1405 - Exhaust Gas Recirculation (EGR) Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0487 - Exhaust Gas Recirculation (EGR) Throttle Control ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0400 - Exhaust Gas Recirculation (EGR) Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Exhaust gas recirculation (EGR) specifications for the AF... Diesel Engine Technology
No new posts Problem mit Abgasrückführung? On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Korrektur der Abgasrückführung On-Board Diagnostics (OBD)
No new posts Quakgeräusche der Abgasrückführung / TDI 130PS Diesel Engine Technology
