ESD for 1Z and part number 028 130 201 HX. Is it compatible with 1Z?
1Z-TDI
Post23-05-2004, 13:36    Subject: ESD for 1Z and part number 028 130 201 HX. Is it compatible with 1Z? Quote
Hello.
I'm looking for ESD injectors for my 1Z TDI, manufactured in 1995. I've found some, but the seller doesn't know if the injectors are compatible with the 1Z engine. However, he has the part numbers.
Part No. 028 130 201 HX
Can someone help me and, based on the above number, tell me whether these nozzles fit a 1Z model or not. The seller wrote that I should call VW and inquire about something, but I don't think today is a good day to do that.
Thank you very much.
Post23-05-2004, 13:48    Subject: Re: ESD for 1Z and part number 028 130 201 HX - Compatible with 1Z? Quote
1Z-TDI wrote:
Can someone help me and, based on the above-mentioned number, tell me if these nozzles fit in a 1Z or not. The seller wrote that I should call VW and inquire about something, but I don't think today is a good day to do that.
Try it here:
http://ecat-online.bosch.de/toc/de/XRA4OF0ZWVGZ4BWZHHY0MTI.srv?view=VIndexJsp
When using the direct article search, enter the number without the "X".
Opening pressure [bar]: 190
Nozzle holder: Dual-spring nozzle holder.
Nozzle holder: with needle movement sensor.
AUDI - A4 (8D2, B5) - 1.9 TDI
12.95-11.00 03.96-06.00 55 75
1896
01.95-11.00 -07.96 66 90
1896
AUDI - A4 Avant (8D5, B5) - 1.9 TDI
02.96-09.01 -07.98 66 90
1896
AUDI - A6 (4A, C4) - 1.9 TDI
06.94-02.97 - 66 90
1896
AUDI - A6 Avant (4A, C4) - 1.9 TDI
06.94-12.97 07.94-10.97 66 90
1896
AUDI - CONVERTIBLE (8G7, B4) - 1.9 TDI
06.95-08.00 07.95- 66 90
1896
AUDI - 80 (8C, B4) - 1.9 TDI
09.91-12.94 08.92- 66 90
1896
AUDI - 80 Avant (8C, B4) - 1.9 TDI
07/92 - 01/96 08/92 - 66 90
1896
1Z-TDI
Post23-05-2004, 14:36    Subject: ESD for 1Z and part number 028 130 201 HX. Is it compatible with 1Z? Quote
Thank you, Bertil.
I checked earlier, but unfortunately without success, because I was searching with 'X'. However, I've had success now. As you mentioned, these nozzles are for Audi, but what's the difference? Does Audi also have 1Z engines?
Can I also install this ESD in a golf cart?
I'm sorry, but I'm just a beginner and still have a lot to learn.
Thank you for your patience with me.
Post23-05-2004, 15:42    Subject: ESD for 1Z and part number 028 130 201 HX. Is it compatible with 1Z? Quote
1Z-TDI wrote:
I checked earlier, but unfortunately without success, because I was searching using "X". However, I've had success this time.
"X" simply indicates a replacement part.
As you already mentioned, these nozzles are for Audi, but what is the difference? Does Audi also have 1Z engines?
The engine in these Audis is mounted longitudinally, which means that minor modifications to the 1Z engine from the Golf are possible.
I wouldn't install just that nozzle alone.
1Z-TDI
Post24-05-2004, 6:12    Subject: ESD for 1Z and part number 028 130 201 HX. Is it compatible with 1Z? Quote
OK, thank you for the information.
togu
Post02-07-2006, 22:31    Subject: ESD for 1Z and part number 028 130 201 HX. Is it compatible with 1Z? Quote
Hello.
Since I'm also interested in this, I'm digging up this information; I found it on Google. (I have a Golf 1Z and I'm wondering if the Audi injector with needle lift actuator will fit.)
The Audi 1Z engine uses the same standard fuel injectors as the Golf 1Z engine.
The three nozzles each have the part number 028 130 201 G (GX).
Only the nozzle with the needle lift actuator differs.
Audi 1Z has the part number 028 130 201 H (HX).
The Golf 1Z has the part number 028 130 201 J (JX).
The nozzle itself is likely the same, but the supply line is longer on the Audi.
I wonder if it would work flawlessly in a golf environment?
Is the cable longer simply because of the different routing required for the longitudinally mounted Audi engine? Surely they wouldn't manufacture two different nozzles just for 10 cm of cable. They could have simply extended the line to the nozzle.
Or perhaps it's a resistance wire and that's why it's of different lengths?
If so, can the cables be simply replaced, and how are they attached to the nozzle? Perhaps someone has already disassembled a nozzle using NHG (presumably a specific cleaning agent or solvent).
Perhaps someone here can offer some advice.
Thank you.
togu
Rudi
Post03-07-2006, 6:31    Subject: ESD for 1Z and part number 028 130 201 HX. Is it compatible with 1Z? Quote
They would even create a completely separate product based on a difference of just 3 centimeters in length.
If the Audi injector has the longer cable, it can be used in a Golf. Conversely, nothing icon_wink.gif will probably happen.
The cable is crimped/molded into the nozzle side.
Rudi
No new posts DPF Loose Parts: Buy Now & Save! Diesel Engine Technology
No new posts Adapter cable parts for Powerbox Diesel Engine Technology
No new posts 2.5 TDI: Parts in the oil pan Diesel Engine Technology
No new posts Vintage Radios: Share Too Much? On-Board Diagnostics (OBD)
