KPower Performance Test: Troubleshooting Guide
im-111
Karma: +0 / -4   Thank you, like it!
Post15-07-2006, 14:35    Subject: KPower Performance Test: Troubleshooting Guide Quote
I would like to purchase the test set offered here.
Okay, I've downloaded it now so I can try it out.
Can my opinion ever be correct, or am I doing something wrong?
I equipped my VW Golf TDI 130HP with a power box (genuine SPEED-Buster).
The performance test resulted in 138 kW (in 4th gear), which is already the average value, as I drove the route twice in both directions to avoid any minor inclines at the end.
It's not that difficult once you've made sure the inputs are correct.
My question is now, can the result be correct?
However, only 127 kW was measured in 3rd gear.
Translated on 11-09-2026, 9:01.
heri
Post16-07-2006, 7:45    Subject: KPower Performance Test: Troubleshooting Guide Quote
Hello.
The data seems reasonable for my case. There are two very sensitive inputs: on the one hand, the vehicle weight, and on the other hand, the tires. The weight actually matters down to a few kilograms, and the tire circumference also significantly affects the result. Try experimenting with these data and check the plausibility.
Best regards, Heri.
Translated on 11-09-2026, 9:02.
im-111
Post16-07-2006, 10:27    Subject: KPower Performance Test: Troubleshooting Guide Quote
I was able to determine the weight very precisely.
"Only the tire size is not specified. A value of 1.00 is given, but I don't know what to do with it, since the rolling circumference is usually around 1800-2100?"
Therefore, I kept the value, but I'm wondering if the performance will be reduced.
I have 225/45/17 tires on.
I've heard that diesel engines from VW supposedly have 5-10 horsepower more than advertised, but I'm not sure if that's true.
Translated on 11-09-2026, 9:03.
No new posts Draft Test / Performance Test 2000-4000 rpm Technical Articles
No new posts Touran 1T: Fueling Problems & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Performance Test A4 2.5TDI Automatic with KPower On-Board Diagnostics (OBD)
No new posts VAG Emission Test: Unusual Performance Results Diesel Engine Technology
No new posts KPower: Calculation Accuracy and Precision On-Board Diagnostics (OBD)
No new posts KPower - unreadable file Upload
