Swap-but how?
Bertl100
Karma: +1 / -1   Thank you, like it!
Post31-07-2006, 17:00    Subject: Swap-but how? Quote
Hello
Is there somewhere an instruction manual on how to disassemble and reassemble the nozzles and nozzle holders?
Can you make mistakes or is it very easy to put it back together?
The instructions on how to replace the entire nozzle holder combination are well described here, but not the nozzles themselves.
Does anyone have any idea?
Back to top Profile PM Email
Bertl100
Post31-07-2006, 17:02    Subject: Swap-but how? Quote
I am considering whether to buy 4 new nozzles for €79 on eBay.
I need to know first if I can replace them myself.
Nebelwerfer_TDI
Post31-07-2006, 17:16    Subject: Swap-but how? Quote
There are very good guides available; you just need to look for them. However, you shouldn't expect to find an instruction manual here that explains how to install competing products (since Rainer does that too). I won't give you what you want or what I want.
However, I am sure that you will find something if you search intensively icon_wink.gif
Here's the translation:
There's a guide available as a PDF, but it's in English. Now, let's think about how it might be called in English to install the nozzles! (but this was already a lot of help)
EDIT: I just searched for it, and found it after 10 seconds icon_smile.gif
Bertl100
Post31-07-2006, 17:21    Subject: Swap-but how? Quote
you are right
I just found a user manual from the seller.
"Although it is written in English, as the seller is based in the USA, I am familiar with technical English, which is my area of expertise."
If they want someone, then I'll put them here, if it's allowed.
Best regards
Bertl
Nebelwerfer_TDI
Post31-07-2006, 17:23    Subject: Swap-but how? Quote
It's definitely the one I meant; This one is often copied, and even offered in German in its unadulterated form...
Post31-07-2006, 20:55    Subject: Swap-but how? Quote
Simply screwing it in is a matter of luck. Whoever thinks they need it, should go and get the parts somewhere.
I've already dealt with more than one "expert" who thought they knew everything and tried to take advantage of me, using just a 15mm wrench and then completely messing things up.
Hello, Rainer
No new posts Modified Engine Noise After Nozzle Replacement (Experienc... Technical Articles
No new posts BMW 525 tds Turbocharger Replacement Diesel Engine Technology
No new posts Düsentausch VP vs PD Diesel Engine Technology
No new posts Nozzle swap when?? T4 TDI ACV, 230,000 km Diesel Engine Technology
No new posts Nach Düsentausch quietscht es???? Diesel Engine Technology
