Pump Cable Pin 8: Troubleshooting & Info
Marko
Post05-12-2002, 12:31    Subject: Pump Cable Pin 8: Troubleshooting & Info Quote
Hi!
While I was just looking at my pump cable, I noticed that pin 8 is missing and not present on the connector.
The pin configuration is 1-8 for the 2.5 TDI AAT engine.
Since the cable has a wire that's tapped into the overall wiring harness, I'm wondering what pin 8 is for.
Best regards: Marko
Lieber TDI statt lahme Ente!
-A6 4B2 2.5 TDI AYM-
Translated on 07-09-2026, 0:52.
Post06-12-2002, 15:57    Subject: Pump Cable Pin 8: Troubleshooting & Info Quote
Hi.
Pin 8 of the 8-pin pump cable is not connected, at least in the case of the 1.9 models.
Translated on 07-09-2026, 0:53.
Marko
Post08-12-2002, 12:17    Subject: Pump Cable Pin 8: Troubleshooting & Info Quote
Hi!
Could it be a control interface for a GRA (Graphics Rendering Accelerator)?
Translated on 07-09-2026, 0:54.
Post08-12-2002, 13:19    Subject: Pump Cable Pin 8: Troubleshooting & Info Quote
Marko wrote:
Could there be a driver for a GRA?
No, even the schematics with GRA (presumably referring to a specific standard or technology) do not assign a function to pin 8 of the 8-pin connector.
Is pin 8 assigned? Where does the wire leading to the pump side go?
Marko
Post08-12-2002, 13:22    Subject: Pump Cable Pin 8: Troubleshooting & Info Quote
Hi Ulf!
The K.a. wire is definitely tapped below the connector and runs to the pump.
Cu: Marko
Translated on 07-09-2026, 0:55.
Post08-12-2002, 13:24    Subject: Pump Cable Pin 8: Troubleshooting & Info Quote
Marko wrote:
The cable, as far as I can tell, is cut below the plug and leads to the pump.
Hi Marko,
Unfortunately, I can't help you further; I only know about the 1.9 version.
No new posts Pump Cables for 10C Tuning Diesel Engine Technology
No new posts Pump Cable: Cheap Tuning for Your Pump Diesel Engine Technology
