GRA A4 2.5 TDI: Specs, Review & Price
merlin
Post08-12-2002, 22:33    Subject: GRA A4 2.5 TDI: Specs, Review & Price Quote
Hi everyone,
I want to retrofit the GRA (Gear Range Adaptor), and I've already obtained the steering column lever, connector, contacts, etc., and I also have the logic code, but...
On the circuit diagram, there's a connection labeled with the number 65 inside a rectangular box, and I can't figure out what it means. Here's a photo of the diagram:
http://www.markus-merk.de/audi/gra.jpg
Can anyone tell me what kind of connector this is?
Bye and thank you.
merlin
Translated on 01-11-2026, 9:40.
Rudi
Post08-12-2002, 22:51    Subject: GRA A4 2.5 TDI: Specs, Review & Price Quote
am unteren Rand des Stromlaufplans findest du Zahlen. Unter der 65 müsste eine Andere stehen. Such mal die Stelle mit der 65, dann müsstest Du dort ein Kästchen mit der anderen Zahl finden. Da Let's continue.
Best regards, Rudi.
Translated on 01-11-2026, 9:41.
merlin
Post08-12-2002, 22:54    Subject: GRA A4 2.5 TDI: Specs, Review & Price Quote
Unfortunately, no! While all the relays and control units are listed with their numbers, this specific one (65) is not included.
Rudi
Post08-12-2002, 22:59    Subject: GRA A4 2.5 TDI: Specs, Review & Price Quote
Please provide some information about your car (year of manufacture, engine code, etc.).
Rudi.
merlin
Post09-12-2002, 6:58    Subject: GRA A4 2.5 TDI: Specs, Review & Price Quote
Okay, so we have an Audi A4 Avant, manufactured in 2000, with a 2.5 TDI V6 engine and quattro all-wheel drive, and the engine code is AKN.
Wie mann dem Plan entnehmen kann gehen alle Drähte nach vorne in´s M-STG. NDon't use these for the 65!
M.
Translated on 01-11-2026, 9:42.
Rudi
Post09-12-2002, 9:16    Subject: GRA A4 2.5 TDI: Specs, Review & Price Quote
It connects to a secured plus port on the steering column.
Best regards, Rudi.
P.S. You've got mail.
merlin
Post09-12-2002, 10:28    Subject: GRA A4 2.5 TDI: Specs, Review & Price Quote
Thanks, Rudi... 'dauerplus' (meaning 'constant plus' or 'always on'), ignition, does it matter?
Is there a specific connection required?
Translated on 01-11-2026, 9:43.
Rudi
Post09-12-2002, 12:31    Subject: GRA A4 2.5 TDI: Specs, Review & Price Quote
If the SLP is compatible: A70 – Connection (15A, fuse 231), within the distribution board wiring.
Best regards, Rudi.
