AKF Stuttering: No Gas Intake - Troubleshooting
Rick78
Post09-09-2006, 16:27    Subject: AKF Stuttering: No Gas Intake - Troubleshooting Quote
Hello!
Since I'm new here, I'd like to briefly introduce myself:
I drive a 2001 A8 3.3 TDI S-Line with 104,000 km on the odometer, and I'm from Luxembourg.
"Recently, the AKF (presumably a piece of equipment) has been malfunctioning and is reporting the following errors:"
VAG-COM Version: DRV 311.3-S
Control unit part number: 4D0 907 409 A.
Component or version: 3.3l/4VTEDC G400AG D04
Software Coding: 00016
Workshop Code: WSC 02314
5 errors found:
17650 - Fuel injector, cylinder 6 (N84), interruption.
P1242 - 35-10 - - - Interrupted.
17649 - Fuel injector, cylinder 5 (N83), interruption.
P1241 - 35-10 - - - Interrupted.
17601 - Fuel pressure sensor (G247) - Open circuit/Short circuit to positive.
P1193 - 35-00 - -
17603 - Fuel pressure control valve - Open circuit/Short to ground.
P1195 - 35-00 - -
19561 - Switching valve for throttle control (N239) - Short circuit to ground / Open circuit.
P3105 - 35-10 - - - Interrupted.
Where do you think I should start the troubleshooting? Which measurements would you recommend I take to identify the cause of the problem?
Thank you for any advice!
Rick.
Translated on 26-10-2026, 13:17.
Post09-09-2006, 16:39    Subject: AKF Stuttering: No Gas Intake - Troubleshooting Quote
I would start by examining the wiring harness starting from the control unit, checking all the connectors and cables, and seeing if the control unit has gotten wet.
Translated on 26-10-2026, 13:20.
Rick78
Post09-10-2006, 10:32    Subject: Bug Found! Troubleshooting Guide. Quote
Thanks for the tip, Rainer. The workshop has identified the cause of the problem.
The error messages related to fuel pressure were triggered by a leak at a connection on a fuel line. Inside the "V" of the engine block, the diesel was 2 cm high icon_sad.gif.
An injector is faulty, and all 8 need to be replaced.
The repair, including the replacement of the control arms, will cost almost 5,000 euros.
My question is: Are there any alternatives to the expensive original parts for the injectors? I haven't been able to find any so far.
Rick.
Translated on 26-10-2026, 13:21.
vagtuning
Post09-10-2006, 11:49    Subject: AKF Stuttering: No Gas Intake - Troubleshooting Quote
Why should they all be replaced?
They should be able to replace the one that's defective.
Translated on 26-10-2026, 13:22.
Rick78
Post09-10-2006, 13:52    Subject: AKF Stuttering: No Gas Intake - Troubleshooting Quote
Unfortunately, all 8 of them need to be replaced.
All 8 injectors need to be replaced, as there is a risk of damage to the other injectors later on.
If injectors with index H were already installed in the vehicle as part of a previous repair, only the defective injector needs to be replaced.
Rick.
Translated on 26-10-2026, 13:23.
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air Suspension Failure: Allroad Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV TDI: No Gas Pedal Response? On-Board Diagnostics (OBD)
No new posts Golf 5 BGU 1.6 FSI - No throttle response Gasoline Engine Technology
No new posts AGR Off: No Gas Response? Troubleshooting Guide. Diesel Engine Technology
No new posts RWG Voltage High: No Gas Intake - Help! On-Board Diagnostics (OBD)
