audi80
22-10-2006, 21:39 Subject: Audi 80 B4: Error Codes & Adaptation |
Hello everyone!
I am looking for a valid login for STG 8A0 907 401 B or 0 281 001 185.
Unfortunately, the logins "12233" or "26262" are not working.
2) If so, what adaptation channels does this ECU have?
3) What does this error code mean (it appears multiple times in the log)?
00000 - End of Output
text
00-00 - -
Regardless of which tester is used (Bosch, Gutmann, etc.).
4) This error with the specific subgroup "Signal to high" is not documented in the repair manual; it only mentions what to do for implausible values.
01242 - Output Stages in Control Module
06-10 - Signal too high - Intermittent.
Thank you.
George.
Translated on 20-08-2026, 10:58.
22-10-2006, 21:50 Subject: Audi 80 B4: Error Codes & Adaptation |
Hi Georg,
Is the engine control unit (ECU) software genuine? If not, you may have found the cause of the problem.
Translated on 20-08-2026, 11:02.
Profile PM WWW Garage |
Ross-Tech-Support Profi-Schrauber
22-10-2006, 23:03 Subject: Audi 80 B4: Error Codes & Adaptation |
Perhaps it would have been more appropriate to respond in the existing thread...
Since you say this occurs with every tester, either Rainer's suggestion is correct, or the control unit is defective. Furthermore, as usual, it's questionable why you need a login to resolve your problem...
Translated on 20-08-2026, 11:04.
wolfi_b Profi-Schrauber
23-10-2006, 7:01 Subject: Audi 80 B4: Login Codes, Errors & Adaptation |
audi80 wrote: | | 8A0 907 401 B |
Is that a 1993 model with 184 Nm of torque? As far as I know, there's no adaptation needed for that. What exactly do you want to adapt? 1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 20-08-2026, 11:06.
audi80
23-10-2006, 21:07 Subject: Audi 80 B4: Error Codes & Adaptation |
"@Rainer: It seems to be original as far as I can tell; at least, it looks like the original soldered-on EEPROMs --> no socket or anything like that (but that doesn't necessarily mean anything)."
"To everyone else: I'm trying to counteract the aging process of the mass airflow sensor and the engine control unit, without getting my hands dirty just yet, to see if this improves my power loss."
"Where near Salzburg, Lienz, or Innsbruck could I have my STG (throttle body) tested affordably? Or do you have a better suggestion, perhaps to try swapping it out temporarily? But where would I even find one if, according to Bosch eCat, it's only installed in this specific model?"
Thank you.
George.
Translated on 20-08-2026, 11:09.
audi80
23-10-2006, 21:23 Subject: Audi 80 B4: Error Codes & Adaptation |
I think my control unit is really broken! I couldn't access it for the first time today, and there was no response! It was working perfectly fine yesterday!
greetings
georg
Translated on 20-08-2026, 11:11.
audi80
24-10-2006, 15:17 Subject: AI Multi USB Adapter: Direct Connection |
Hi everyone!
Regarding the AI multi-USB adapter, it can also be connected directly via USB without requiring any software to convert it to a COM port.
I need to test this more thoroughly, but I'll report back later!
georg
Translated on 20-08-2026, 11:12.
audi80
25-10-2006, 17:17 Subject: Audi 80 B4: Error Codes & Adaptation |
The direct connection using the AI MultiScan USB driver works perfectly, and it also enables smoother operation with VAG-COM. --> Blocking is almost non-existent now!
georg
Translated on 20-08-2026, 11:13.
