VP37 Nut: Special Nut for VP37
Post01-11-2006, 11:01    Subject: VP37 Nut: Special Nut for VP37 Quote
HI,
Is there an official nut for the triangular head screw of the VP37?
The technical article on disassembling the MSW recommends building it yourself using a size 7 nut.
Translated on 21-09-2026, 0:59.
clm24
Post01-11-2006, 11:39    Subject: VP37 Nut: Special Nut for VP37 Quote
Hi!
Are you absolutely sure you need that specific type of nut, or would you like a tip on how to remove the screw? I'm not sure if that kind of nut exists.
As far as I know, there are three possible options for the screw.
1. The method described in the article for modifying a 7-series nut.
2. The exact opposite: You carefully grind down the rounded parts of the screw with a Dremel or similar tool, transforming it into a hex screw. Then, a regular socket wrench will fit. Admittedly, it requires some delicate work.
3. Use the Dremel to cut a slot into the screw, then use a sturdy flathead screwdriver (possibly with the help of pliers) to unscrew it. A tap on the screw will make it easier to loosen.
Best regards, Clemens.
Golf 3 Variant, '97, ALE, 203.000 km
Wenn er nicht so rosten würde...
Translated on 21-09-2026, 1:01.
Post01-11-2006, 12:56    Subject: VP37 Nut: Special Nut for VP37 Quote
Well,
Ideally, I would like to get the part out and back in without using any machining, sawing, or other methods that involve material removal.
Therefore, the question arises: where can I find a genuine nut?
Translated on 21-09-2026, 1:02.
Max d. Ä.
Post01-11-2006, 19:51    Subject: VP37 Nut: Special Nut for VP37 Quote
Why put it back in? I chewed out the slot, removed the screw with a flathead screwdriver, and then replaced it with a standard hex screw. Why do you want to reuse the screw?
Bye.
Max.
Post03-11-2006, 0:02    Subject: VP37 Nut: Special Nut for VP37 Quote
"Just throw away that stupid three-sided screw after opening it, put in a normal Allen screw, and that's it! Finding a three-sided wrench is too much hassle, and it's unnecessary to spend money for a one-time use! Or are you fixing multiple ESP guitars so that it's worth it?"
Translated on 21-09-2026, 1:03.
vc
Post05-11-2006, 1:41    Subject: VP37 Nut: Special Nut for VP37 Quote
Set screws with triangular heads are standardized (DIN - I'm sorry, I can't recall the exact number at the moment) and are commonly used to protect 'ex-d' enclosures from unauthorized opening. (What is an 'ex-d' enclosure? 'ex-d' refers to explosion protection achieved through a pressure-resistant casing; these enclosures are very common in the chemical industry, such as at companies like Bayer and BASF.) The corresponding wrenches are available in any good hardware store under the name 'Ex-tools' as tubular wrenches with a triangular profile.
Translated on 21-09-2026, 1:04.
Herr Antje
Post06-11-2006, 11:43    Subject: VP37 Nut: Special Nut for VP37 Quote
dieselmartin wrote:
Hey Tom.
Where can I find the nut?
How do you know that Würth has it?
Do you even have an order number?
Sorry, T3Surfer says they are available at Würth, and since I also work in the automotive industry, I know who Würth is, and I just wanted to provide you with a link.
Since I don't want to leave you hanging icon_wink.gif, I've done a little more searching. I no longer have a catalog from Würth. There's nothing in the Hazet catalog. There is something in the Hahn und Kolb catalog, but I don't know if it's what you're looking for, based on what I found.
Go to hahn-kolb.de, under "online-shop," then "test access," and enter "52170" in the search bar. It doesn't cost much (probably between €2.30 and €4.30, excluding VAT), if it's what you're looking for.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 21-09-2026, 1:06.
Post06-11-2006, 11:49    Subject: VP37 Nut: Special Nut for VP37 Quote
Thank you, Tom.
You can find these triangular crimping tools by searching for "52170*".
I don't really trust them, though.
And sorry for not reading carefully who wrote what.
Translated on 21-09-2026, 1:07.
No new posts Disassembling the metering unit of a VP37 Troubleshooting & Guides
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts Injector sizes for TDI engines with distributor injection... Technical Data
No new posts ESP VP37 Diesel Engine Technology
No new posts Golf 3 TDI 1Z/ VP37 Diesel Engine Upload
No new posts VP37 Issue: AFN in T3 Van On-Board Diagnostics (OBD)
No new posts Check VP37 Diesel Engine Technology
