cksIT Blaumann
Joined: 05/22/2004 Posts: 399 Karma: +18 / -0 Location: Riedstadt
01-07-2005, 10:49 Subject: Boost Pressure Increase 1Z |
I've already done some searching about the aldehyde pressure increase on the 1Z.
I could only find information about the newer engines that connect directly to the 1Z, but nothing about the 1Z itself. Of course, you could drill holes in the hose and adjust the wastegate. The first option is probably obvious why it would fail...
I don't want to adjust anything on the wastegate, because it's very difficult to access and you can only adjust it a tiny bit.
"Does the engine control unit (ECU) update now also work for the 1Z engine? Or is there still another method I can use to increase the boost pressure by 0.2 bar?"
"Background: "
I have a chip from Princiotta installed. Now I also got a set of brand new injectors from AFN, and the engine seems to be trying to imitate a diesel truck. It's really extreme what it's putting out. It's somewhat manageable on cold days, but on hot days, I can barely see anything behind me. That's why I wanted to increase the LD (likely referring to Lambda/Air-Fuel Ratio) a bit.
I'm completely convinced of its performance. It's running really well now. If it just gets enough airflow...
Is it actually absolutely necessary to be able to solder SMD components?
Translated on 22-10-2026, 15:38.
01-07-2005, 11:03 Subject: Boost Pressure Increase 1Z |
Hi.
Have you read the technical article about the "10Cent Tuning" method?
The same applies to the 1Z engine and the turbocharger pressure.
Adjusting the wastegate used to be common, but there's nothing left to adjust on a TDI.
Translated on 22-10-2026, 15:40.
Profile PM Garage |
cksIT Blaumann
01-07-2005, 21:05 Subject: Boost Pressure Increase 1Z |
Yes, but I have no idea which resistor I need to replace.
Does anyone happen to have a picture of that, or do you know how I can find it?
Has anyone ever done this before?
I would like to write a detailed guide, but I need to finish it first.
Translated on 22-10-2026, 15:41.
cksIT Blaumann
07-07-2005, 12:42 Subject: Boost Pressure Increase 1Z |
Quote: | The boost pressure can be increased by reducing the measurement voltage. In the pressure sensor located in the engine control unit, replacing the 10 kOhm SMD resistor behind the sensor output (trace the circuit board from the middle solder pin to the resistor) with, for example, 18 kOhm results in an increase of approximately 0.1 bar, while 27 kOhm results in an increase of approximately 0.2 bar.
"Is it the same with the resistance values for the 1Z? Does that mean I would need a 27kohm resistor to achieve 0.2 bar more pressure? I've read in the technical article that my measurement range only goes up to 1 bar. Has anyone experimented with this before?"
Can someone explain to me again exactly where this resistor is located? I'm not really understanding it.
Do I need to trace the middle pin from the sensor (i.e., where the hose connects)?
I just don't want to make a mistake, that's why I'm asking again.
"0.2 bar would be enough for me, as it hardly produces any soot on cold days. However, on warm days, I can't see anything behind me anymore."
"Thank you in advance."
Translated on 22-10-2026, 15:43.
wolfi_b Profi-Schrauber
07-07-2005, 13:11 Subject: Boost Pressure Increase 1Z |
Quote: | | Now, I have learned from the technical article that my measurement range only goes up to 1 bar. |
"Where does it say that? That's only for the 184Nm 1Z engine, but that wasn't available in the G3. As far as I know, yours has a 250 kPa sensor (which is equal to 1.5 bar of boost pressure)."
The sensor is located directly in the control unit, and so is the resistor.
Wie hoch ist eingendlich dein jetziger Ladedruck? Sure, here's the translation:
"Series?"
Edit: You have a chip (or a device) inside, right?
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 22-10-2026, 15:45.
cksIT Blaumann
07-07-2005, 18:41 Subject: Boost Pressure Increase 1Z |
Quote: |
For older vehicles equipped with the MSA 12 engine control unit (identified by a plastic instead of a metal housing), the measurement range may end as low as 1 bar of overpressure if the internal pressure sensor housing has the part number 0 273 003 204 or ... 209.
At minimal increases in pressure, you're already entering a range where the data is no longer reliable, so it's best to avoid such tests unless you have a backup system available.
The sensors with a higher measurement range have the model numbers 210 (1.5 bar) and 211 (2.0 bar), respectively.
I have a plastic housing, so I thought the pressure limit was only up to 1 bar.
Now I'm wiser.
Is the resistor highlighted in red in the image the correct one?
I basically just need to replace it.
What about the values now? Do I need to replace the resistor with one that has a value of 27k ohms to achieve 0.2 bar more pressure?
"Yes, I have a chip from Princiotta installed. It's a really good piece of equipment, but it's not overly aggressive. That's why it doesn't adjust the boost pressure. I'm currently at about 0.85 bar."
It's a bit too small for chip and exhaust valves.
It starts smoking in a disturbingly suggestive way when it gets hot.
| Description: |
| File size: |
375.1 KB |
| Viewed: |
3343 times |
Translated on 22-10-2026, 15:48.
08-07-2005, 15:17 Subject: Boost Pressure Increase 1Z |
It says 250 kPa on yours, so there's no problem.
I'm afraid I don't know which one you need to replace.
Quote: | | Trace the conductor from the middle solder pin to the resistor | .
It appears that it's not the one circled in red, but the one above it. However, it's best if you judge for yourself.
Do you have experience soldering SMD components? If not, you should probably find someone else to do it.
1993 Audi 80 B4 1Z
Translated on 22-10-2026, 15:51.
cksIT Blaumann
12-07-2005, 6:45 Subject: Boost Pressure Increase 1Z |
oops
"Sorry, yes, I meant the one above. I circled the wrong one in my haste..."
Actually, wouldn't it also work if I took a regular 0.5W resistor and soldered it to one of the sensor's legs, and then connected the other end to the right leg of the blue component? I can simply desolder the SMD resistor.
"Or are there any other problems? I know a few people who can solder SMD components, but I don't have a workspace where I can do it."
Thank you in advance for your help!!
Translated on 22-10-2026, 15:52.
Rudi Guest
12-07-2005, 7:47 Subject: Boost Pressure Increase 1Z |
[edited by Rudi]
There wasn't really anything substantial here.
[edit]
Rudi
Translated on 22-10-2026, 15:53.
cksIT Blaumann
12-07-2005, 11:18 Subject: Boost Pressure Increase 1Z |
Hello!
"I definitely have a chip in there, and it can be removed and replaced with a regular soldering station. You can simply desolder it and solder in a new one."
And fundamentally, it doesn't matter whether the signal travels through a trace or directly from leg to leg. And you can manage without SMD equipment!
I even have a rather expensive chip. This part costs about 500 euros (princiotta). Of course, it's not directly adjusted, but that doesn't matter. Because now I just need to compensate for the increased fuel consumption with more air. After that, the chip can go back to its usual function, with the difference that everything is just a little more.
Besides, I'm not just tearing around everywhere; I'm actually warming it up properly! There are definitely no long stretches of full throttle.
--- Censored by Georg-TDI ---
Translated on 22-10-2026, 15:54.
dj1 Guest
12-07-2005, 11:43 Subject: Boost Pressure Increase 1Z |
Oh dear, just reading something like that...
Oh man...
Translated on 22-10-2026, 15:55.
Georg-TDI Guest
12-07-2005, 11:59 Subject: Boost Pressure Increase 1Z |
Hey everyone,
That's inappropriate and doesn't belong in a public forum!
Please clarify the rest via private message.
That's why we're already seeing the first reactions.
Rudi Guest
12-07-2005, 12:32 Subject: Boost Pressure Increase 1Z |
Please provide the text you would like me to translate from German to English. I will then provide the translation without any explanations.
I definitely have a chip, and if you had thought for a moment, you would also know that the chip is not an SMD component. You can remove it with a regular soldering station and replace it with a different one.
You probably mean a base or platform when you say 'shoe,' and it's clear that the memory chips inside the control unit are wired in. I was referring to your box.
and, in principle, it doesn't matter whether this goes through the circuit board or directly from leg to leg.
You're right...
and you can manage without SMD equipment!
Can you also use MELF resistors for...? If not, it's probably best to avoid using them.
I even have a rather expensive chip. This part costs about 500.- (princiotta)
AFAIK vertreibt Priciotta keine Chips, sondern nur verpacktes 10ct 'Tuning'. Should I?
I apologize for misleading you.
It's not directly adapted, but that's not a problem.
If it's actually a chip, that definitely makes a difference... It affects the programming of the tuning.
During software development, it was sometimes necessary to push the limits of the available hardware.
You've changed it now - but until you know exactly which fields have been modified,
The risk of damage is significantly higher than with a box.
because now I only need to compensate for the increased amount of fuel with an increased amount of air. After that, the chip can go back to its usual task, with the difference that everything is just a little more.
Sure, why would one even bother to regulate any kind of temporal dependencies  ?
Besides, I'm not revving the engine like a maniac all over the place, but I do warm it up properly! Long periods of full throttle are definitely not happening!
While that's great for you and the engine, how do your girlfriend or other drivers treat the car?! If you're already tinkering with the car, it should...
The result should also be practical for everyday use.
Rudi
P.S. Of course, you can solder in a resistor with leads (a 1/4W size is sufficient).
However, if you want something that actually works well, it's better to also invest the money in customizing the software.
'Addendum:'
@Georg:
I just can't type fast enough  .
The content should be okay }.
Translated on 22-10-2026, 15:59.
cksIT Blaumann
13-07-2005, 7:31 Subject: Boost Pressure Increase 1Z |
Okay, I meant the base.
I don't have a tuning box installed. And Princiotta does indeed produce chips, and they're quite good; I can gladly send you a test one. The chip only produces a little over 20 horsepower, so I'm not really worried about it.
Besides my girlfriend, nobody drives a car, and even she never revs it above 2500 RPM, whether the engine is cold or warm.
Quote: | | Sure, why would anyone want to regulate any kind of temporal dependencies | ?
"Actually, the injectors themselves didn't change anything in terms of timing... only the chip made a minimal adjustment. And if it were injecting for too long, shouldn't that already be a problem without the injectors, or am I mistaken?"
Regarding everyday usability: Every engine should be warmed up and cooled down properly. My engine is just a bit more sensitive in that regard.
"Since it runs much better with these injectors (no more jerking or other issues), I don't see any problem with it. I've already driven about 4000 km (100 km per day) with these injectors, and if there were any critical issues, I would have noticed them by now. Besides the turbo itself, what could potentially go wrong if I increase the LLD (low-level diesel) pressure? Does increasing the LLD pressure change the injection process?"
"I also understand that a software adjustment would be the best solution, but that requires money, which I don't have right now. I was also hesitant about replacing the nozzles, but since I needed new ones anyway, why get the smaller ones? A software adjustment would probably cost me another 500 euros. If it can work this way, I actually prefer it."
Translated on 22-10-2026, 16:04.
Rudi Guest
13-07-2005, 10:51 Subject: Boost Pressure Increase 1Z |
...I don't have a box inside. And, in principle, Princiotta does manufacture chips.
Okay, sorry about that. I've only ever seen boxing matches from those guys. Do you happen to have a link?
and quite good.
What are you basing that on?
, I would be happy to send you a test.
Sure,  PM.
The chip only produces a little over 20 horsepower, so I'm not too worried about it.
20PS sind IMO für einen 1Z mit normalen Düsen eine gesunde Größenordnung. Allit
Anything that goes beyond that becomes borderline (my opinion - commercial tuners).
(may see it differently).
Besides my girlfriend, nobody drives the car, and she never drives it above 2500 RPM, whether it's cold or warm...
What if you sell the car?
...in terms of timing, the injectors themselves didn't change anything... only the chip made a minimal change. And if it were injecting for too long, shouldn't that already be a problem without the injectors, or am I mistaken right now??
The injectors behave somewhat differently in terms of 'when, at what RPM, how much, and for how long fuel is injected.' However, my statement was more related to the assumption of a fixed configuration. Ultimately, it really depends on how the chip is programmed.
since it runs so much better with these injectors (no more jerking or other issues), I don't see any difficulty in it. I've already driven about 4000 km (100 km daily) with these injectors, and if there was something critical, I would have noticed it a long time ago...
Unfortunately, you often only notice piston skirt scoring abruptly. It also depends heavily on the driving profile (I also drive over 100 km per day - in my old Volvo).
I only realized when I got out that it had been running on only five cylinders, because of the smell of diesel.
and besides the turbo itself, what could potentially become critical if I increase the LDP (low-pressure injection) pressure? Doesn't the injection process remain the same, or does it change?
It depends. If the engine is currently running at its maximum allowable operating limit, then increasing...
It can also lead to an increase in the amount of fuel injected. It's unclear whether it's operating at its limit.
but this can be determined using a VAG-COM log.
Da du einen Chip drinhast, ist der Ladedruck vermutlich schon angehoben. Question would be...
'how high' and from that, what's still possible (or whether one should adjust a different 'setting').
should film).
... I also didn't want to do that with the nozzles yet, but since I needed new ones anyway, why get the small ones again...
especially because it also reduces the shaking/vibration.
For a software customization, I'll probably have to pay another 500.- .
It depends... With a reputable tuner, whose product you've purchased, you should...
a software change can be implemented at a much lower level (this is not intended to be...).
(I can't say anything about the rating of Princiotta).
If it can be done that way, I honestly prefer it.
I would still like to check where the set boost pressure is currently at.
and whether any quantity adjustments are made based on the turbidity.
Rudi
Translated on 22-10-2026, 16:10.
cksIT Blaumann
13-07-2005, 13:23 Subject: Boost Pressure Increase 1Z |
Quote: | | What are you inferring? |
from the test I have at home. I'm not sure how quickly I'll be able to scan it though.
Quote: | What if you sell the car?
Since I don't have the money for a new one, that won't happen anytime soon. And then I'll put the old injectors back in, along with the original chip and a small resistor. I would never sell a car like that; most people have no idea how to drive it.
although, when it's warm, you can't really do much wrong...
Quote: | It depends. If the engine is currently running within the permissible emission limits, then an increase in...
This can be determined using a VAG-COM log.
"how high" and from that, what's still possible (or whether one needs to adjust a different 'setting').
should film).
How exactly can I determine that? I would need to check that beforehand!
The boost pressure is not increased because, at this performance level, it relies solely on the excess air. That's why I didn't have any concerns that there might be problems.
Quote: | It depends... With a reputable tuner, whose product you have purchased, you should...
They live quite far away. That's the problem. I have no idea if they would offer a lower price, but I could ask them.
The current boost pressure is too low. While it's still within the tolerance range, 0.83 bar is quite low. It's supposed to be up to 0.9 bar. Even a slightly higher pressure would help, as very little exhaust gas recirculation (EGR) comes out in cold weather. With 0.2 bar of EGR, I could easily pass the emissions test (ASU).
Translated on 22-10-2026, 16:19.
