'My Passat 1Z, manufactured in '94, occasionally exhibits a relatively mild, regular 'shaking' or 'vibration' under partial load conditions (up to approximately 2500 RPM). This shaking disappears when I accelerate.'
This shaking isn't just an illusion; it's particularly annoying, especially on country roads or highways (around 85 and 105 km/h), when you're trying to maintain a constant speed.
Occasionally, I also notice a slight, unusual fluctuation in the idle speed, by a few RPM.
I've already tested the knock sensor with the 'knock test,' but it seems to be working fine.
I've read online a few times that cleaning the fuel injection system can be helpful, so I wanted to ask if anyone has had any experience with that.
I imagine it like this: You buy a diesel cleaner, for example, from Liqui-Moly, but instead of putting it in the tank, you disconnect the hoses from the diesel filter and let the engine draw the cleaner directly into the system using the starter.
Once you've done that, it's likely to be beneficial to let the fuel system soak with the cleaner for a few hours before reconnecting the normal fuel lines to the filter.
What do you think about this????
Could such jerking also be caused by the much-discussed relay 109?
Can this be checked in any way, since my error memory is empty?
(Is a faulty relay displayed there?)
The engine otherwise runs very well, meaning it delivers its power (90 horsepower
The shaking/jerking is independent of the temperature!
Thank you, Best regards, BASTI!
