ECU for 1Z: Buy Online & Save!
gamma-ray
Post26-07-2005, 15:39    Subject: ECU for 1Z: Buy Online & Save! Quote
Hi there.
"Does anyone have any idea where I can find an engine control unit (ECU) for a Passat 1.9 TDI, year 1995 (engine code 1Z)? Unfortunately, I only have the Bosch part number (0281 001 312/313). I'm missing the original VW part number."
I've checked with all the used parts dealers (and there are quite a few in Berlin), but no luck.
Can someone give me a tip?
Thank you.
Translated on 26-10-2026, 12:31.
Post26-07-2005, 17:47    Subject: ECU for 1Z: Buy Online & Save! Quote
In the Gulf region, the license plate number was 028 906 021 AF.
That should fit.
like the BF and the GG (but the latter must be encoded).
You can find similar items at regular auction houses as well.
m
Translated on 26-10-2026, 12:32.
Rudi
Post26-07-2005, 18:22    Subject: ECU for 1Z: Buy Online & Save! Quote
The VAG part number 0 281 001 313 corresponds to 028 906 021 AK.
Rudi
Mati
Post26-07-2005, 22:04    Subject: ECU for 1Z: Buy Online & Save! Quote
Both VW part numbers are correct.
Register with online used parts dealers, and they will...
then properly sift through the databases for you icon_wink.gif.
Good luck!
Greetings.
Mati.
Translated on 26-10-2026, 12:33.
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ECU and MAF Sensor: Troubleshooting & Repair On-Board Diagnostics (OBD)
No new posts Only ABS control unit??? On-Board Diagnostics (OBD)
No new posts AFN control unit On-Board Diagnostics (OBD)
No new posts Control Unit: What it is & How it Works Diesel Engine Technology
