Blechmann Guest
05-07-2005, 9:53 Subject: 1Z Nozzles: 0.216mm for Best Results |
Hat jemand eine gute Bezugsquelle für o.g. Fuel injectors?
I've obtained prices from Bosch and VW, and I have to say... is that a typo?
I am grateful for any tips and suggestions!
Translated on 31-10-2026, 8:07.
Blechmann Guest
05-07-2005, 18:12 Subject: 1Z Nozzles: 0.216mm for Best Results |
Thank you for the quick responses!
Oops, complete sentences are also available here.
http://shop.dieselschrauber.de/index.php/cPath/36
The price differences compared to VAG are really enormous...
I still have one question... The AXG nozzles have an opening pressure of 220 bar. Can that remain the same if the old ones only have 190 bar?
golf3schrauber Blaumann
Joined: 10/15/2003 Posts: 140 Karma: +1 / -0 Location: Erkelenz
07-07-2005, 6:02 Subject: 1Z Nozzles: 0.216mm for Best Results |
I've been running 205 injectors in my 1Z engine for the last 30,000 kilometers.
The transit time, from 2000 to 4000 RPM in third gear, has improved by 1 second.
Russians are not recognizable anymore.
The increased power output is roughly equivalent to using a 1 kOhm resistor. However, the 10-cent resistor caused more instability in the lower load range, while the nozzles did not. Gruss Oliver.
GolfIII,1Z,66KW,von94 mit 500tKm !
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
Translated on 31-10-2026, 8:08.
Blechmann Guest
12-07-2005, 18:06 Subject: 1Z Nozzles: 0.216mm for Best Results |
Another question about the nozzle replacement:
After all the mechanical work is completed, I need to inform the EDC (Engine Control Unit) that there are now different injectors. Measurement block 1 in the engine management system is used for this purpose, and the injected amount should be approximately 3-5 mg/R (whatever 'R' represents).
QUESTION:
Can I also perform this adjustment with a 1551, or is VAGCOM required?
Translated on 31-10-2026, 8:10.
Rudi Guest
12-07-2005, 19:42 Subject: 1Z Nozzles: 0.216mm for Best Results |
I believe that...
You misunderstood something...
Measurement block 1 (regardless of whether using VAG-COM or 1551/1552) displays engine speed and actual fuel injection quantity.
(now incorrect), RWG measures voltage and coolant temperature - that's all.
You cannot adjust the nozzles through adaptation. To do so, the chip would need to be modified.
Rudi
Translated on 31-10-2026, 8:11.
R.M. Schrauber
Joined: 06/15/2004 Posts: 389 Karma: +14 / -0 Location: DD
12-07-2005, 19:51 Subject: 1Z Nozzles: 0.216mm for Best Results |
@Blechman:
You probably mean adaptation channel 1, where you can completely increase or decrease the injection amount?
Based on my personal experience, I can tell you that an adaptation is not necessary (at least with the AFN 0.205 -> 0.216). However, a good chip with adjusted characteristic curves can still be beneficial.
Translated on 31-10-2026, 8:12.
Blechmann Guest
13-07-2005, 20:14 Subject: 1Z Nozzles: 0.216mm for Best Results |
Thank you for the correction; I meant adaptation channel 1.
An adjustment of the amount is urgently recommended due to the significant change in nozzle size from 0.184 to 0.216.
Please provide an accurate answer, taking into account the exact specifications (1Z, 0.1 bar more boost pressure, 0.216 size, no chip tuning).
So, to reiterate:
Is it possible to make adjustments using a 1551 device, or is VAG-COM more suitable?
Translated on 31-10-2026, 8:13.
Joined: 04/12/2002 Posts: 18142 Karma: +807 / -0 Location: St.Gallen 2018 Volkswagen T6
13-07-2005, 20:28 Subject: 1Z Nozzles: 0.216mm for Best Results |
Blechmann wrote: | | Is an adjustment possible using 1551, or is VAG-COM more suitable? |
Both options work, it doesn't matter which tool is used to set it.
The question is whether this is necessary. Depending on the opening pressure of the old/new injectors, it's possible that the engine control unit may even need to inject 'more' fuel at idle than before, and the displayed injection amount may then be even larger.
Personally, I would rather adjust it by repositioning the quantity setting mechanism and reserve the adaptation feature for fine corrections due to wear.
Translated on 31-10-2026, 8:14.
Profile PM WWW Garage |
Blechmann Guest
14-07-2005, 18:19 Subject: 1Z Nozzles: 0.216mm for Best Results |
Thank you for the helpful answer, Rainer!
The opening pressure remains the same (190), otherwise I would experience a delayed injection process and would likely have to compensate for it.
I'll just wait and see how he behaves with the new nozzles... it's possible that no adjustments will be necessary.
Translated on 31-10-2026, 8:15.
R.M. Schrauber
14-07-2005, 20:06 Subject: 1Z Nozzles: 0.216mm for Best Results |
Most likely, you wouldn't experience any shift because the injection process starts within a standard cycle (sensor = NBF).
Translated on 31-10-2026, 8:16.
Blechmann Guest
12-08-2005, 8:04 Subject: 1Z Nozzles: 0.216mm for Best Results |
So, dear community!
It is done...
The nozzles are in place, and I can only say WOW!
This renovation was definitely worth it!
Here are some facts about the car:
- Intake passages de-restricted.
- Increased boost pressure by 0.1.
- Injection time slightly extended due to signal distortion from the flow control valve.
- Soot emissions are not higher than those of any modern diesel engine.
- Suit: WOW!
After assembling the engine, I didn't even need to bleed it. I just drained the bleed lines, and after 8-10 seconds of cranking, it started. I put the bleed lines back on and went for a test drive.
I've noticed that it sounds louder when idling (meaning it's knocking more), but it's within acceptable limits, and an untrained ear wouldn't even notice it.
Translated on 31-10-2026, 8:17.
