joop Guest
06-09-2002, 18:55 Subject: A6/AEL: Why No Speed Above 3000 RPM? |
Hello!
'I'm having this problem. The car accelerates normally up to 3000 RPM, but then it stops accelerating. There are no error codes stored. When using a diagnostic tool while driving, the values are correct up to 3000 RPM, but then the actual values for lambda (LD) and air mass drop.'
I've already checked the turbocharger boost hoses, and I don't see any other visible issues.
Who else can help me here...?
'Thank you.'
Sure, here's the translation:
'Best regards,' or 'Sincerely,'.
Okay.
Translated on 19-09-2026, 11:21.
Hannes Blaumann
Joined: 08/25/2002 Posts: 64 Karma: +6 / -0 Location: Graz
06-09-2002, 23:03 Subject: A6/AEL: Why No Speed Above 3000 RPM? |
Have you ever checked the needle lifter?
Let the engine run at approximately 3000 RPM, and then, by gently tapping the nozzle with the needle valve adjuster, the engine should not start to stumble. If it does, a replacement is necessary.
best regards
Hannes. Audi Allroad quattro LR, 2004
Audi S6 Avant quattro, 1995
Translated on 19-09-2026, 11:22.
joop Guest
07-09-2002, 8:27 Subject: Needle Valve: Definition & Function Explained |
Hello.
First, thank you for your help.
But that's a dumb question. Can you explain to me what the needle lift valve has to do with my problem? Wouldn't a defective needle lift valve be noticeable through sporadic fluctuations in performance...?
Best regards.
Okay.
Translated on 19-09-2026, 11:23.
olli Profi-Schrauber
Joined: 05/24/2002 Posts: 581 Karma: +46 / -0 Location: Berlin
07-09-2002, 13:10 Subject: A6/AEL: Why No Speed Above 3000 RPM? |
"On my car, there was a hose (about 5 mm in diameter) that was located very close to the EGR valve. A broken cable tie caused it to come into contact with the hose, which then melted."
To inspect it, you need to remove the upper motor cover.
I no longer remember exactly whether it connects to a sensor for measuring pressure or vacuum, but the resulting effect was similar.
Performance is normal up to approximately 3000 RPM, after which it drops off significantly.
Olli.
Translated on 19-09-2026, 11:24.
Hannes Blaumann
07-09-2002, 14:23 Subject: A6/AEL: Why No Speed Above 3000 RPM? |
It started with occasional jerking when my NHG (presumably a type of engine or component) was faulty, and it happened more and more frequently. Eventually, I also experienced a complete loss of power under heavy load.
Also, you should also check the CAT (computer-aided translation) tool to see if it might be malfunctioning.
best regards
Translated on 19-09-2026, 11:25.
