EUV Control: Charging Pressure Regulation System
prittstift69
Post22-09-2005, 16:46    Subject: EUV Control: Charging Pressure Regulation System Quote
Hello.
A question about the EUV (Electric Switching Valve):
Does anyone have any idea what the typical duty cycle and frequency of the PWM signal used to control a turbocharger wastegate for boost pressure regulation are (for a VW Golf TDI with an AGR engine, specifically the Pierburg SI 0051)?
Regarding the EPW (Electro-pneumatic pressure converter for EGR control or VTG turbocharger), I found the following values in the Pierburg SI 0065 documentation:
Duty cycle: 20-95%.
Frequency: 250-300 Hz.
Thank you.
Stephan Leci.
Translated on 11-08-2026, 21:18.
Post22-09-2005, 17:14    Subject: EUV Control: Charging Pressure Regulation System Quote
Hi Stephan,
The duty cycle depends on the throttle position, engine speed, etc. icon_smile.gif
How else? The search function is the key.
Translated on 11-08-2026, 21:20.
Post22-09-2005, 18:12    Subject: EUV Control: Charging Pressure Regulation System Quote
Rainer K. wrote:
The throttle ratio depends on the accelerator pedal position, engine speed, etc.
... and the frequency is likely to be very similar or identical due to the almost identical designs of the EGR and VTG valves.
Translated on 11-08-2026, 21:21.
No new posts Turbocharger Boost Control Problem - Golf4 AXR Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty Load Pressure Control Engine Identifier BRE Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ansteuerung Abstellklappe Diesel Engine Technology
No new posts Ansteuerung des N108 Diesel Engine Technology
No new posts PDE Control: Questions and Answers Diesel Engine Technology
No new posts Interface for controlling the central locking system Electrical Systems, Vehicle Electronics, Multimedia
