| TDI Injector Replacement: DIY Guide & Tips | |
| dieselschrauber |
To replace the injectors on a TDI engine with a distributor injection pump (Audi, Seat, Skoda, VW), you will need the following tools:
The previous nozzle holder combinations can be equipped with new injectors and adjusted. You can find information here about which nozzles have which properties.
The nozzle holder combinations are easiest to remove from the warm engine. First, the cylinder head cover (plastic cover) must be removed. Before proceeding with the work, the engine should be reasonably clean. If it is not, carefully clean the cylinder head, for example, by using an engine cleaning service. When working on the fuel injection system, it is absolutely essential to pay attention to cleanliness!
Extension: Then, place cleaning cloths under the fuel injection pump lines, as fuel will leak out when the screws are loosened.
Loosen the locking nuts on the injector nozzles and remove the injector lines. Place the injector lines on the clean paper towel. Now that access to the nozzle holders is clear, the power bridge for the glow plugs can be removed, and the screws on the retaining claws of the nozzle holder combinations can be loosened. Place the nozzle holder combinations on the clean paper towel. If the nozzle holder combinations need to be transported, wrap them securely in clean paper towels. Also, cover the openings in the cylinder head to prevent dirt from entering.
Nozzle Tip Replacement:If completely new nozzle holder assemblies are installed, this point is not applicable. However, if only the nozzle tips are replaced (using nozzle repair kits), the nozzle holder assembly with the nozzle tip is clamped in a vise, and the union nut is opened with a 15 mm wrench. Caution: If the nozzle tip is carbonized with the union nut, loosen them with light hammer blows while continuing to unscrew them. If this is not done, the guide pins inside may break, and the nozzle holder will be scrap.Extreme cleanliness must be observed during the work! After installing the new nozzle tips, the nozzle opening pressure must be checked and, if necessary, adjusted. At a minimum, the idle speed control must be checked using VCDS in measurement block 13 of the engine control unit! You can Clean the openings for the nozzle holder combinations in the cylinder head using cotton swabs and oily paper towels. The sealing surface must be absolutely clean; it
Then, attach the new copper sealing rings to the injector nozzles so that the rounded side of the sealing ring faces the cylinder head, and push the entire nozzle holder assembly back into the cylinder head. When tightening the fuel injection lines, make sure that the lines are not twisted or strained! This will eventually lead to the lines breaking! With the engine running, check everything for leaks. Apply a few drops of oil (or a 10% detergent / 90% water mixture) to the gap between the injector holder assembly and the cylinder head. Bubbles indicate leaks. Carefully tighten the mounting screws. Leaks can cause the injectors to overheat and can damage the injectors and the cylinder head, so please work carefully.
https://community.dieselschrauber.org/en/viewtopic.php?t=26850 Translated on 19-09-2026, 4:03. |
| Ratings - TDI Injector Replacement: DIY Guide & Tips | |
Average rating: 4.30 - worst rating: 1 - best rating: 5 - number of ratings: 10 - View ratings |
Foren- und Portal-Software: V8.0 © 2003 - 2026 Kaufmann Automotive GmbH & Shop für Kfz-Diagnosegeräte. Parse time: 0.048s
