Coolant Temperature Sensor
Bertl100
Karma: +1 / -1   Thank you, like it!
Post20-09-2005, 14:01    Subject: Coolant Temperature Sensor Quote
Hello fellow mechanics!
I would like to replace my coolant temperature sensor.
Can someone tell me where it is located?
Audi A3 1.9 TDI
BJ: 99
110 horsepower.
AHF
Best regards.
Bertl.
Translated on 19-09-2026, 22:30.
Back to top Profile PM Email
Post20-09-2005, 14:20    Subject: Coolant Temperature Sensor Quote
When you're standing in front of the engine, at the right end of the cylinder head, you'll find it. It's secured with a retaining clip and has a connector with 4 pins attached to it.
When removing it, some coolant will leak out, so it's best to have the new expansion tank ready in the other hand; you just have to be quick enough icon_mrgreen.gif.
Translated on 19-09-2026, 22:31.
renwal
Post20-09-2005, 15:21    Subject: Coolant Temperature Sensor Quote
Let the car cool down for 2-3 hours beforehand, otherwise you might get burned fingers. icon_smile.gif
Have some coolant and water ready in case the change doesn't go as quickly as expected.
renwal
Translated on 19-09-2026, 22:32.
Bertl100
Post20-09-2005, 16:08    Subject: Coolant Temperature Sensor Quote
Great!
Danke für die Antworten. A really great forum.
Best regards.
Bertl.
Translated on 19-09-2026, 22:33.
bloesch
Post20-09-2005, 17:47    Subject: Coolant Temperature Sensor Quote
If the radiator cap is difficult to remove, open the coolant reservoir first (be careful, there may be pressure buildup).
Lightly dampen the (new) O-ring from the supplier with coolant.
No new posts Coolant temperature sensor Audi 100 C4 AAT Diesel Engine Technology
No new posts Coolant Temperature Sensor G62, Caddy 06, 1.9 TDI BLS Diesel Engine Technology
No new posts Coolant Temperature Sensor Passat 35i - Specs Diesel Engine Technology
