Golf III TDI Starting Problems: 1996, 1Z Engine
Daniel
Post07-09-2002, 19:39    Subject: Golf III TDI Starting Problems: 1996, 1Z Engine Quote
Hello TDI experts,
My Golf has been starting very poorly for the past three days. It only starts with full throttle and about 5 seconds of cranking, and it doesn't matter if the engine is cold or warm. This problem appeared suddenly, overnight. When it does start, there are no other issues, and I haven't noticed any loss of power. I've also tried a different relay (relay 109).
Do you have any ideas?
Thank you.
Daniel.
Translated on 19-09-2026, 22:06.
Post07-09-2002, 19:48    Subject: Golf III TDI Starting Problems: 1996, 1Z Engine Quote
What does the error memory say?
Have you checked the lower timing belt pulley? Perhaps the screw is loose, and your injection timing is no longer correct.
Translated on 19-09-2026, 22:07.
Daniel
Post07-09-2002, 20:10    Subject: Golf III TDI Starting Problems: 1996, 1Z Engine Quote
Thank you for your quick response.
I went to the workshop, and they read the error codes and connected a diagnostic tool.
I believe that the emission values are within acceptable limits.
They also tested the battery, starter, and generator.
Could the throttle valve in the intake manifold be defective?
Best regards, Daniel.
Translated on 19-09-2026, 22:08.
Daniel
Post07-09-2002, 20:50    Subject: Golf III TDI Starting Problems: 1996, 1Z Engine Quote
I've checked again, and I've discovered an air bubble between the diesel filter and the fuel injection pump. How do I get it out?
Translated on 19-09-2026, 22:09.
Post08-09-2002, 7:59    Subject: Fuel System: Types, Problems & Solutions Quote
Hi Daniel,
"Your fuel system is drawing in air somewhere. Have it checked for leaks. Possibly, a seal between the pump and the fuel line has become damaged. It doesn't necessarily have to be diesel leaking out, but air could be getting sucked in! Also, check the fuel filter; I once had one that cracked, and air got in."
When the engine is running, the air automatically escapes, and the system self-bleeds.
I am not familiar with a throttle valve in the intake manifold of the 1Z engine.
Translated on 19-09-2026, 22:10.
Daniel
Post10-09-2002, 19:25    Subject: Golf III TDI Starting Problems: 1996, 1Z Engine Quote
I followed your advice and replaced the diesel filter, but unfortunately, that wasn't the problem. Then I checked the diesel lines in the engine compartment with a 'leak detection spray,' but I didn't find anything.
A friend mentioned something about a diesel pre-heater and said it might be the cause, possibly because it's leaking.
Do you think that's possible, or can you think of any other reasons?
Translated on 19-09-2026, 22:11.
Stukov
Post11-09-2002, 8:07    Subject: Golf III TDI Starting Problems: 1996, 1Z Engine Quote
The 'diesel pre-heater' is the valve that sits on the diesel filter; it's the (usually) white part to which the diesel return line and the hose back to the tank are connected. Normally, when changing the diesel filter, you only remove the clip, detach the part, and reattach it to the new filter.
Sometimes things break, develop a crack, or something similar. The part itself costs just under €12.
Translated on 19-09-2026, 22:12.
Post11-09-2002, 9:18    Subject: Golf III TDI Starting Problems: 1996, 1Z Engine Quote
The small diverter valve located at the top of the diesel filter, used for preheating, has one or two seals that are prone to failure if the connected hoses move too much due to vibration.
With my last diesel filter, there were even 2 new sealing rings included. Installed -> no more bubbles in the line to the fuel injection pump. icon_smile.gif
The leak was minimal and not noticeable.
Translated on 19-09-2026, 22:13.
Daniel
Post11-09-2002, 17:05    Subject: Golf III TDI Starting Problems: 1996, 1Z Engine Quote
Thanks for the tip, I'll try replacing it and see if it gets better.
Translated on 19-09-2026, 22:14.
No new posts TDI engine starts poorly Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf 3 TDI: Cold Start Problems? Diesel Engine Technology
This topic is locked, you cannot edit or reply. TDI engine starts poorly when warm! Diesel Engine Technology
No new posts Golf 3: 1.9 TDI Engine Starting Problems Diesel Engine Technology
No new posts Engine hard to start when warm Diesel Engine Technology
