P-Box: Unlikely Load Pressure Signal
TherealXAVeR
Karma: +0 / -1   Thank you, like it!
Post05-10-2005, 11:38    Subject: P-Box: Unlikely Load Pressure Signal Quote
Hi there,
A few months ago, I bought a "P-box" (from P-Box.at) *g* on eBay for my Seat Toledo 110 HP TDI with an ASV engine... It's working wonderfully since I adjusted the box.
"However, I have a problem: when I drive at full throttle on the highway for a while, my engine goes into limp mode, and I have to turn it off and restart it. Then it works normally again (usually after 2-3 minutes, depending on the weather and temperature, I think - when driving at full throttle). When the diagnostic computer is connected at my car dealership, it shows: 'implausible boost pressure signal'."
icon_arrow.gif Do I need to adjust the chip further, even though it only causes problems outside of the highway when under full load, or can I solve the problem in some other way??
It would be great if someone had a tip.
Translated on 10-10-2026, 12:15.
Post05-10-2005, 12:07    Subject: P-Box: Unlikely Load Pressure Signal Quote
Oh no.
Unfortunately, I can't think of anything to translate.
What do you think? Do you think this thing will go into emergency mode because everything is okay?
Translated on 10-10-2026, 12:17.
Post05-10-2005, 14:41    Subject: Boost Pressure Sensor Issue: P-Box Troubleshooting Quote
TherealXAVeR wrote:
During error reading, the diagnostic tool in my car dealership shows: "implausible boost pressure signal"
I consider this error message to be relatively unlikely.
If it's been acting up since the box was set up -> what's more logical?
(My crystal ball can't provide more information without specific error messages or log values.)
Translated on 10-10-2026, 12:18.
hharry
Karma: +2 / -1   Thank you, like it!
Post12-10-2005, 7:05    Subject: P-Box: Unlikely Load Pressure Signal Quote
"The additional module likely passively increases the boost pressure at full load, eventually exceeding the upper tolerance limit of 2250 mbar in the ASV/AHF system, which then triggers an error message and causes the system to enter a limp mode."
It would be beneficial to install a lambda sensor (LDA) to monitor the boost pressure.
A likely solution would be to increase the boost pressure using a diode tuning method, as described in this forum.
"Hello"
harald
Translated on 10-10-2026, 12:19.
