Control Unit Memory Issues
chrisstoeckl
Post02-02-2006, 12:59    Subject: Control Unit Memory Issues Quote
Hello everyone!
Posting here for a friend, as I want to help him with his problem.
It's about a VW Caddy (year 2005).
'Short story:'
The Caddy has been completely refurbished after suffering flood damage.
All the control units have been replaced!
At the VW plant, the software was also installed.
It then worked fine... for a few kilometers.
After that, all sorts of warning lights come on, and the lighting stops working (tail lights, etc.).
However, the engine is still running.
The control unit seems to have lost all of its data again.
The game can be repeated many times.
Does anyone know of a situation where a control unit completely loses its software? What could be the cause of this?
I understand that this is quite limited information, but maybe I'll get lucky.
Please provide the text you would like me to translate from German to English.
Understeer is when you...
Seeing the tree and oversteering is something you can tell just by listening.
Translated on 27-10-2026, 12:09.
Post02-02-2006, 13:09    Subject: Control Unit Memory Issues Quote
It is very unlikely that a new control unit, regardless of the type, would lose its data. It is much more likely that you have various loose connections in the wiring harness or the fuse box.
I would recommend using new parts in this case, so it's best to replace them.
Also, all grounding connections should be checked to ensure that none have been missed and are properly secured.
Translated on 27-10-2026, 12:11.
Ross-Tech-Support
Post03-02-2006, 12:39    Subject: Control Unit Memory Issues Quote
Control units like the ones installed in your Caddy typically do not have memory that is dependent on the power supply, and furthermore, your error descriptions do not align with that possibility.
Hast du von dem Fahgrzeug ein Diagnoseprotokoll vorliegen? Ist sichergestellt, das die Kabelbäume kein Wasser gezogen haben, sprich wurden diese gewechselt? All/Which?
Which warning lights specifically come on? Can you describe the individual malfunctions in more detail?
Translated on 27-10-2026, 12:12.
[email protected]
Post31-03-2006, 23:33    Subject: Control Unit Memory Issues Quote
"I've also experienced situations where the wiring harness absorbed water, causing the accelerator to stop working. Turning the ignition off and on again would temporarily fix it, but then the intervals between failures would become shorter until nothing worked anymore. It would be helpful to know exactly which functions are affected. I don't think the engine control unit is suffering from dementia."
Translated on 27-10-2026, 12:13.
Back to top Profile PM Email
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ECU and MAF Sensor: Troubleshooting & Repair On-Board Diagnostics (OBD)
No new posts Only ABS control unit??? On-Board Diagnostics (OBD)
No new posts AFN control unit On-Board Diagnostics (OBD)
No new posts Control Unit: What it is & How it Works Diesel Engine Technology
