leo_b Blaumann
Joined: 02/03/2005 Posts: 145 Karma: +1 / -0 Location: Hamburg
31-03-2005, 21:34 Subject: Car Starting Problems with Low Fuel? |
Lately, I've been experiencing some difficulty starting the car when the fuel tank is below a quarter full.
Then the startup process takes approximately 2-4 seconds.
It feels like there's air in the fuel line.
If the tank is full, the engine starts immediately.
Where should I start looking?
Engine specifications:
- VW T4 TDI, 88 hp / 65 kW
- 157,000 km
- Fuel filter replaced in 12/04.
- Slight diesel leakage detected near the ES injectors on the engine.
"Hello Leo_b"
Translated on 27-08-2026, 2:52.
Günther Guest
31-03-2005, 21:39 Subject: Car Starting Problems with Low Fuel? |
Do you have a pre-pump in the tank?
Günther.
Translated on 27-08-2026, 2:54.
rinderwahnsinn Guest
01-04-2005, 10:08 Subject: Starting Problems When Tank Is Empty? |
Sure!
Hoses, seals (thermostat!), hose clamps, etc.
CU.
01-04-2005, 10:38 Subject: Car Starting Problems with Low Fuel? |
I experienced the same problem with my first G2 D.
There's a tiny hole somewhere in the fuel line that allows air to enter but prevents diesel from escaping.
That is, you don't see any wet spots or droplets, but air can be drawn into the lines – preferably when the tank has a correspondingly low fuel level.
Ignore or search forever  .
m; Transparency, Teamwork
Translated on 27-08-2026, 2:55.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18099 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
01-04-2005, 10:47 Subject: Car Starting Problems with Low Fuel? |
Quote: | | - reduced diesel loss in the engine area near the ES injectors | .
How about you start your search by checking the beer hose connections?
Translated on 27-08-2026, 2:56.
Profile PM WWW Garage |
leo_b Blaumann
01-04-2005, 16:34 Subject: SEO-Optimized Website Design: Tips & Tricks |
thank you!
leo_b Blaumann
18-10-2005, 13:31 Subject: Beer Can Sleeves: The Culprits! |
It's been a while, but:
Thank you for the great help!
best regards, leo
Translated on 27-08-2026, 2:57.
18-10-2005, 14:46 Subject: Leaky beer lines: The culprit revealed! |
leo_b wrote: | Thank you for the great help! |
And what was the reason for it now? Gruß Ulf
Profile PM Garage |
leo_b Blaumann
18-10-2005, 16:39 Subject: SEO-Optimized Title Translation:
"Title Translation: German to English" |
I only put it in the title.
Title: "It was the leaky beer hoses!"
best regards, leo
Translated on 27-08-2026, 2:58.
18-10-2005, 16:55 Subject: Leaky beer lines: The culprit revealed! |
leo_b wrote: | It's been a while, but:
hello leo |
Please
18-10-2005, 17:16 Subject: SEO: Best German to English Translation Services |
leo_b wrote: | I only put it in the title:
"Title: It was the leaky beer hoses!" |
Oops, whoever doesn't read carefully...  Gruß Ulf
Translated on 27-08-2026, 2:59.
Profile PM Garage |
