Pajero 2800 TD: Performance Issues & Stalling
reuselkopp
Post17-06-2007, 12:48    Subject: Pajero 2800 TD: Performance Issues & Stalling Quote
Hi everyone,
"A friend of mine owns a Pajero 2800 intercooler and is having some problems with it. The problems manifest as a loss of power when accelerating fully. We measured the boost pressure while driving, and when the problem occurs, the boost pressure drops to 0.6 bar. The maximum pressure is 0.7 bar (which is the standard pressure). I believe it's a wastegate turbo. However, I don't think there's a boost control valve there. He also has a pressure regulator with a rod. That seems to be working fine. We've replaced some hoses, but the power loss still occurs."
Does the Pajero also have a wastegate valve? Is anything controlled electronically in that vehicle? Does anyone have any ideas?
Greetings.
Reuselkopp.
Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Translated on 30-10-2026, 6:39.
No new posts A4 B6 2.5 TDI 180 hp BAU, power loss below approximately ... Diesel Engine Technology
No new posts 1.4 TDI AMF: Turbocharger boost only from 2800 RPM Diesel Engine Technology
No new posts Audi A3 1.9 TDI: No Power Below 2800 RPM Diesel Engine Technology
This topic is locked, you cannot edit or reply. Audi A3 TDI: Low Power, Fix at 2800 RPM Diesel Engine Technology
