Hello!
Here's the translation:
'This is about the following vehicle:'
Seat Ibiza GT TDI.
MKB: AFN engine with switchable chip (110/140 hp) from ******** (installed for approximately 45,000 km).
'Problem: The 'turbo boost' now kicks in around 2300 RPM, instead of the usual 1800 RPM. However, after that, it seems like all the power is available, and the maximum speed is reached. There's just a slight hesitation around 3500 RPM. Whether the 'chip' is installed or not, it doesn't make a difference. In the past, I experienced a complete loss of power. However, after cleaning the mass airflow sensor (Pierburg) with brake cleaner, everything was back to normal.'
So far, I have:
Have the error memory read: No entry
LMM cleaned: Unsuccessful.
Visual inspection of hoses, connectors, etc.
The air and diesel filters are in good condition.
Does the AGR click when actuated externally, so it's working correctly, right?
Disconnecting the AGR (Abgasrückführung) system will not achieve anything.
VTG mechanism is operating smoothly (checked with a syringe).
And now?
Do you have any ideas?
Thank you in advance!
