TDI Engine: Understanding Brake Performance
Klausel
Post16-09-2002, 14:34    Subject: TDI Engine: Understanding Brake Performance Quote
Hello!
I have a G3 with an 81 kW (AFN) engine - my first diesel - and I've noticed that the engine braking effect is significantly weaker than it was in my previous gasoline cars.
I previously thought it was the opposite. There might be a defect, or it could be a normal technical reason (e.g., related to the turbo). I haven't checked the compression, but I haven't experienced any performance issues.
Greetings, Klausel.
Translated on 26-10-2026, 23:48.
Alois
Post16-09-2002, 15:10    Subject: TDI Engine: Understanding Brake Performance Quote
Don't worry, the TDIs have a 'poor engine braking' characteristic, so everything is fine. Diesel engines don't have a throttle valve and don't create negative pressure during coasting. icon_biggrin.gif
Translated on 26-10-2026, 23:49.
Uwe
Post16-09-2002, 18:43    Subject: TDI Engine: Understanding Brake Performance Quote
Hi!
Alois wrote:
TDI engines have "poor engine braking"
Um, that's not entirely correct. TDIs have significantly longer gear ratios compared to gasoline engines, which is why the diesel's "supposedly" weaker engine braking effect. But don't worry, it's not a sign of an engine defect.
Uwe.
Translated on 26-10-2026, 23:50.
Gremlin
Post16-09-2002, 19:43    Subject: TDI Engine: Understanding Brake Performance Quote
Hi!
Um, that's not entirely correct. TDIs have a significantly longer gear ratio compared to gasoline engines, which is why the diesel's 'supposedly' weaker engine braking effect. But don't panic, it's not a sign of an engine defect.
I can't really complain, this case rolls really easily, just like my old 'grandpa-style' case.
but a so-called 'stauklappen-bremse' (aka engine brake) doesn't sound bad at all in a truck... I wonder how that would sound on a TDI? icon_cool.gif
CU Gremlin.
Translated on 26-10-2026, 23:51.
Thomas
Post22-09-2002, 18:52    Subject: TDI Engine: Understanding Brake Performance Quote
Hi Gremlin,
Check out www.papmahl.de.
They offer a type of engine brake for the TDI.
Greetings,
Thomas.
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
Translated on 26-10-2026, 23:52.
