ECU Adaptation: Fuel Injection Timing Explained
Achim
Post14-09-2002, 18:00    Subject: ECU Adaptation: Fuel Injection Timing Explained Quote
I once adjusted the setting of my fuel injection pump after...
Diagram in the technical article 'Tuning the VW 1.9L TDI'.
'The distributor injection pump was checked and it was determined that...'
The value deviates slightly.
Idle.
At a fuel temperature of 150, the value is approximately...
At 50 and measurement block 4, the value is 2.8.
At 3000 revolutions per minute in 3rd gear.
Measurement block 4, value 4 is approximately 45 at idle, and increases to about 90 under full throttle.
Okay, here are my questions:
Is this typical for the ASV?
Does changing channel 4 in the control unit adaptation cause...?
Is this similar to a problem caused by a misaligned fuel injection pump?
Translated on 01-08-2026, 12:56.
Post15-09-2002, 8:16    Subject: Electronics Can't Replace Mechanics Quote
same as a fuel injection pump misalignment?
Hi Achim,
No.
Twisting the pump changes the mechanical baseline setting and shifts the mechanical range within which the electronic control system operates.
If you only adjust the electronic setpoint values via adaptation, the control system can quickly reach a limit in reality due to the possible actual values, so that the intended success of the adaptation may only be partially achieved.
Therefore, after each adjustment, it should be checked using a test run to see if the injection timing control ratio is frequently hitting its limit. If this is the case, the basic setting of the fuel pump should also be corrected.
Translated on 01-08-2026, 12:58.
No new posts Crankshaft Phase & Injection Timing Explained Diesel Engine Technology
No new posts AJM Injection Timing: How To & Troubleshooting Diesel Engine Technology
No new posts Injection Timing Display Diesel Engine Technology
No new posts Injection Timing ALH: Understanding the Basics Diesel Engine Technology
