Hello.
I'm experiencing an intermittent issue with a rough idle. The engine is shaking quite violently during this. This problem only occurs at idle. If I give it a little gas, it goes away, but then usually returns when the engine reaches the idle speed. What could be causing this?
'Interestingly, when I reprogram the engine control unit to '0001' (automatic transmission), the jerking disappears completely.'
It sounds like this:
http://www.polo2f.privat.t-online.de/Aufnahme3.mp3
Is a '99 ALH engine in a Bora?
Paul.
Translated on 12-07-2026, 4:19.
