Several weeks ago, I started a thread about the pin configuration of the combination connector for the boost pressure/charge air temperature sensor on the newer 1.9 TDI engines.
Today, I finally increased the boost pressure. Here's how I proceeded:
"The entire cable bundle was completely severed. Four-pin connectors were soldered on, and corresponding pin headers were attached to the breadboard. Initially, the contacts on the circuit board were connected in a 1:1 fashion, meaning no boost pressure adjustment was implemented yet." I tapped into the boost pressure signal, which is a voltage ranging from 0 to 4.65V, where 1.85V represents idle and 3.75V indicates the regulated maximum boost pressure. I read this signal with a digital multimeter inside the vehicle while driving.
Aggressive drivers who were speeding were, for the most part, not easily provoked; max. The measured value was 3.95 volts, which corresponds to approximately 1.12 bar.
"Using these values as a reference, I then connected a Schottky diode (a standard type, I don't recall the exact model number) in series with the output signal. This time, the circuit was designed so that I could measure the boost pressure signal voltage both before and after the diode." The diode's voltage drop was 0.1V when idle; it was also approximately 0.1V during operation.
I was actually able to further adjust my tuning box without noticeable black smoke emissions. (However, this is a very subjective matter, and I've noticed that the black smoke behavior (triple double s
) somehow depends on the day's conditions.
The change should theoretically only increase the pressure by 0.05 bar. That's a joke. However, the adjustment behavior has changed significantly. Now, when accelerating abruptly from 2500 rpm, I'm seeing overshoots up to 4.2V. I also have the impression that the gas intake has become more spontaneous.
That's all I'll say about that for now...
Okay, here's the translation:
Now, my questions:
Why is the voltage drop only 0.1V? Schottky diodes should have a forward voltage of 0.3V, right?
How much pressure can my loader javascript:emoticon('
') handle?
Laughing?
Best regards, Georg.
