ESP Flow Rate: How to Calculate & Optimize
Diesel-Dirk
Post03-01-2006, 20:09    Subject: ESP Flow Rate: How to Calculate & Optimize Quote
Weiß jemand wie groß der Volumenstrom im Vorlauf der ESP in Abhängigkeit von der Drehzahl beim 1,9er TDI ist? Speziell at the 1Z.
If not, I'll have to measure it myself.
Translated on 28-07-2026, 22:28.
Uli S.
Post04-01-2006, 18:27    Subject: Flow Rate to ESP: How Much? Quote
I can only give you a house number that is circulating in the forums and which I can experimentally estimate to be icon_wink.gif, and which I have used for troubleshooting (air) in the van by directing the return flow into an empty bottle). Afterwards, at the rated speed, approximately 1 liter per minute flows back into the tank, and with full load, correspondingly less. Therefore, the forward flow volume is in this order of magnitude.
The impeller pump of the 1Z is likely identical or very similar, so transferring the specifications seems permissible in my opinion.
Best regards, Uli.
Golf2 GTD AAZ, LLK, CYP
Bus T3 JX
2x Golf2 GTD/SB
97er Golf 3 AFN, 70-100% Pöl
97er Golf 3 Variant AFN
96er Passat 35i AFN
Translated on 28-07-2026, 22:29.
No new posts Ladedruckregelung durch hohen Volumenstrom "entmünd... Diesel Engine Technology
No new posts Luft im CDI Vorlauf? Diesel Engine Technology
No new posts Significant drop in inflow Diesel Engine Technology
No new posts Check Valve for Radiator - Diesel Heater Part Diesel Engine Technology
