Pump Curve Optimization: Improve Performance
solarplexus
Post09-01-2006, 21:26    Subject: Pump Curve Optimization: Improve Performance Quote
After studying the technical articles about adjusting various operating parameters, I modified the pump characteristic curve on my car.
Now I've discovered that reducing the value (i.e., reducing the injection amount) in my car results in better acceleration.
Why does a smaller amount produce more thrust?
Translated on 26-09-2026, 6:07.
Rudi
Post10-01-2006, 0:03    Subject: Pump Curve Optimization: Improve Performance Quote
What is the data status?
What is the address of the vehicle you are modifying?
With what did you modify it, or with what were the checksums adjusted?
Rudi
Translated on 26-09-2026, 6:08.
Post10-01-2006, 0:12    Subject: Pump Curve Optimization: Improve Performance Quote
solarplexus
Post10-01-2006, 8:57    Subject: Pump Curve Optimization: Improve Performance Quote
Adaptation only: original value: 32768, new value: 32738.
No new posts 12mm Pump Adjustment / Pump Calibration Diesel Engine Technology
