Spare key with 4-digit code
garmin
Post15-01-2006, 0:32    Subject: Spare key with 4-digit code Quote
Hello everyone.
My Golf 3, manufactured in 1996 with a WFS (presumably referring to a specific system or component), needs an additional ignition key. I have already read all the relevant threads about this. The original replacement key has a tag with a number consisting of a letter and 6 digits, not the 4-digit login code that was expected.
Do I have the right number, or should I call my friend?
Back to top Profile PM Email
Ross-Tech-Support
Post15-01-2006, 2:05    Subject: Spare key with 4-digit code Quote
There should be a kind of "scratch-off area" on the trailer, and behind it is the WFS login information.
vagtuning
Post15-01-2006, 4:36    Subject: Spare key with 4-digit code Quote
If it's a black trailer, then that's the closing number.
After that, you can order a new key.
garmin
Haegar likes this.
Post15-01-2006, 17:59    Subject: Spare key with 4-digit code Quote
Then it's probably this closing code. I won't be able to do anything with that.
It would be interesting to know if the key tag could be ordered as an original replacement part. After all, it was originally included with the keys. I suppose I'll have to go to the VAG (vehicle registration authority) and ask for the 7-digit code.
Thank you for the answers.
Haegar
Post30-01-2006, 2:23    Subject: Spare key with 4-digit code Quote
You need the WFS code, which is in the car. If you're lucky, you might still have the plastic tag that came with the product from the factory, as it usually has that information on it (up to ~99).
For A4 models up to a certain production year, the pin is even located on the WFS-SG (Windshield Frame Support - Side Glass).
No new posts Key Fob Programming: How-To Guide On-Board Diagnostics (OBD)
No new posts Replacement key cannot be adjusted? On-Board Diagnostics (OBD)
No new posts EDC login code Diesel Engine Technology
No new posts login code On-Board Diagnostics (OBD)
