Henrik Guest
25-01-2006, 11:40 Subject: Servo Oil Cooler: Performance & Durability |
Hello!
Mal ne Frage, wieviel Druck baut der Servoölkreislauf auf? How hot does it get?
Can I use a servo oil cooler as a motor oil cooler?
Translated on 20-10-2026, 16:08.
26-01-2006, 15:58 Subject: Servo Oil Cooler: Performance & Durability |
In a typical servo system, the return line is usually cooled because it operates at (almost) zero pressure.
On the Golf 3, it's a simple metal tube located below the water cooler, and its base has extra holes to allow air to reach the power steering hose.
For the T5 engine, there are 2-3 coils with cooling fins located in front of the water cooler.
Why don't you get a proper oil cooler?
Translated on 20-10-2026, 16:09.
Profile PM Garage |
Henrik Guest
26-01-2006, 17:14 Subject: Servo Oil Cooler: Performance & Durability |
because the servo cooler cost me 15 euros...
There are two rows, but they are incredibly long.
| Description: |
| Kühler der Servolenkung am T5 |
| File size: |
10.16 KB |
| Viewed: |
2029 times |
Translated on 20-10-2026, 16:10.
