Hello first of all
Okay, now for my problem: The control unit for my automatic climate control system is no longer responding.
"When I turn the ignition on and off, the display always shows 'OFF'. When I then press 'Auto', the air conditioning works perfectly, but as soon as I turn the ignition on and off again, everything goes back to 'OFF'."
My friend also tried to access the control unit and read data from it, but without success. He uses his laptop to access other components in a similar way.
I'm really stuck and don't know what to do anymore. Is there a keyboard shortcut or something similar to reset the device? I've also disconnected the battery several times.
Best regards, Carsten!!!
VW Sharan, year of manufacture 1999, 1.9 TDI.
