Hi everyone,
I once logged some data blocks related to my problem (see "Shaking at 2800-3000 RPM, engine revs up to >4000"). The data blocks I logged were 002, 004, and 008. What do you think of these values?
Regarding measurement series 1.
Within the specified RPM range (2800-3000), it's quite noticeable that something is wrong with the injection timing. The RPM then increases rapidly, even with the throttle position held constant.
Do you have any ideas? When I look at the injection start point using the timing checker, it's slightly above the centerline. Injection start at 53, with a temperature of 119.
| Description: |
| Engine Misfire at 2800-3000 RPM? |
 Download |
| File name: |
LOG-01-002-004-008.CSV |
| File size: |
3.13 KB |
| Downloaded: |
428 times |
Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Translated on 06-10-2026, 12:34.
