Why is everyone talking about readjusting the PD elements?
You can test, check, or verify the idle speed control beforehand. If the values are within the expected range and not significantly different from each other, it's okay. Ideally, all values should be around +/- 0.
There is nothing to add regarding the PD elements in the AJM.
The adjustment/calibration (initial setting) can be done on all PDE devices. This also applies to the AJM
. It's simply a matter of setting the 'start of injection' or 'start of spraying,' or performing the initial settings of the PDE devices. A good guide for this can be found on the forum
