Opel Astra: Cold Start Problems - 1.7TD Fix
dokatoto
Post03-03-2006, 20:44    Subject: Opel Astra: Cold Start Problems - 1.7TD Fix Quote
My x17dtl engine only starts after a long cranking period when it's warm. When it's cold, it starts immediately! Once it's running, the check engine light illuminates for a few seconds, then goes out, and the engine runs perfectly fine.
'When the fuel level is below 1/4 and when taking sharp turns, going through roundabouts, or exiting highways, the engine briefly goes into a limp mode. The check engine light flashes briefly, as if the fuel is momentarily running out. I've already checked the fuel tank and the fuel pump, but haven't found anything.'
Maybe someone has an idea before I have to take the car to the dealer next week.
Thank you and best regards.
Toto.
Translated on 11-08-2026, 21:12.
No new posts TDI engine starts poorly Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Transporter 7D, Schiebetüre schließt schlecht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 110 PS AFN springt warm schlecht an On-Board Diagnostics (OBD)
No new posts AFN springt warm schlecht an Diesel Engine Technology
No new posts Van engine T4 ACV starts poorly in both warm and cold con... Diesel Engine Technology
No new posts ASZ starts warm, runs poorly - what could it be? Diesel Engine Technology
