Spark plug question
Jericho
Post14-03-2006, 14:52    Subject: Spark plug question Quote
Enjoy your meal.
My AJM is now due for a glow plug replacement. The starting behavior isn't optimal; it cranks for quite a while. What kind of spark plugs should I buy, or which ones would you recommend?
(Ideally, a model name or similar.)
Herr Antje
Post14-03-2006, 15:26    Subject: Spark plug question Quote
First, I would make sure (if you haven't already) that it's actually the spark plugs. I've often heard and also experienced myself that when the spark plugs need to be replaced, the engine starts, but runs roughly for the first few seconds. There are many possible causes for the "rough idling." I wouldn't just replace the spark plugs without further investigation, hoping it will fix the problem. You don't mention anything about measuring the candles or how many were broken.
Brand doesn't really matter to me, as long as it's a reputable manufacturer and specifically designed for your vehicle. I would mainly focus on the price. Here's another interesting article on this topic:
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Jericho
Post14-03-2006, 15:37    Subject: Spark plug question Quote
Obviously, the word 'orgeln' can have two different meanings. I actually meant an uneven engine running, which only occurs shortly after starting.
Thank you for the response.
Herr Antje
Post14-03-2006, 15:52    Subject: Spark plug question Quote
I only knew/knew engines as things that took a long time to start; the starter motor had to turn for a long time.
Let's measure the candles anyway...
Aktuell:
Jericho
Post14-03-2006, 20:37    Subject: Spark plug question Quote
Okay, I will. Thank you.
No new posts Spark plug firing order Technical Data
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glow Plugs 1Z - Buy Online Now! Diesel Engine Technology
No new posts Ablagerungen an Glühkerzen Diesel Engine Technology
No new posts Glow Plug Replacement Audi A6 C4 AEL Diesel Engine Technology
No new posts Spark plugs are oily!! Diesel Engine Technology
