Schneemann Blaumann
Joined: 08/09/2003 Posts: 78 Karma: +2 / -0 Location: Wissen
21-03-2006, 19:14 Subject: Circuit Diagram Search: Find Your Schematics |
I'm so frustrated with my Golf. It has this quirky alarm system that sometimes doesn't activate when I lock the car, and other times doesn't disarm when I unlock it, which then blocks the ignition and starter. Plus, I always end up waking up the neighbors when the alarm goes off.
"Does anyone have a wiring diagram for this device? The part number is 1H0 953 233 B. It has an 8-pin connector and a 12-pin connector. I downloaded a diagram from a Russian website, volkswagen.msk.ru, but it doesn't match at all. I haven't figured out anything beyond the wire colors and which pin they connect to. So far, I've only managed to incorrectly disable the horn."
It would be really nice if someone could help me with that.
Gruß Schneemann
Golf Plus Highline Bj. 09/2010 CFHC. eFH, eSP, Climatronic, PDC, AHK, ABS, ESP, GRA, MFA, LMAA, FDH, BSE, Brenderup Kippi 200 und ne Traumfrau auf dem Beifahrersitz.
Translated on 28-09-2026, 12:32.
luiggi Schrauber
Joined: 02/19/2006 Posts: 392 Karma: +4 / -0 Location: Tirol /Zillertal
21-03-2006, 22:54 Subject: Circuit Diagram Search: Find Your Schematics |
Hi, is it a 3-door or a 5-door model? And what's the exact year of manufacture?
Translated on 28-09-2026, 12:33.
Ross-Tech-Support Profi-Schrauber
22-03-2006, 10:24 Subject: Circuit Diagram Search: Find Your Schematics |
Schneemann Blaumann
22-03-2006, 17:43 Subject: Circuit Diagram Search: Find Your Schematics |
I have a 4-door model. But the issue is already resolved. I initially used the wrong search terms. "DWA" was the key to success. And, just out of boredom, I completely removed the small control unit and installed three jumper wires. Now it works without it. Still, thanks to you all!
Gruß Schneemann
Translated on 28-09-2026, 12:34.
