Urgent: Differences between GT1749VA and GT1749VB exhaust side
Zak1976
Karma: +0 / -1   Thank you, like it!
Post24-03-2006, 14:55    Subject: Urgent: Differences between GT1749VA and GT1749VB exhaust side Quote
I urgently need information about the GT1749VA and GT1749VB models. Unfortunately, there is very little information available online or from Garrett partners.
What are the differences between the two chargers? Is the exhaust side (exhaust housing + manifold, bearings, turbine wheel, shaft, oil inlet and outlet) the same for both chargers? The compressor side needs to be the same, at least in terms of the shaft, fittings, and compressor impeller.
concerns. So far, the only differences I've found are that the VB model has a narrower intake diameter of 37mm (compared to 35mm for the VA model) and a narrower outlet diameter of 38.3mm (compared to 36.5mm for the VA model).
has. I would also like to know if the exhaust manifold (header) would fit on the ARL engine.
I hope you can write something about it.
"Hey Ulf, could you also contribute something? I understand you have some experience with Garrett turbochargers, as I've read."
Fährt mit Golf 3 TDI Umbau (von AFN auf ARL)
Back to top Profile PM Email
Zak1976
Post25-03-2006, 19:44    Subject: Urgent: Differences between GT1749VA and GT1749VB exhaust side Quote
People, this is really important, can anyone say something about it???
Post25-03-2006, 19:49    Subject: Urgent: Differences between GT1749VA and GT1749VB exhaust side Quote
Hi Zak,
If you've been reading this forum, you've probably noticed that the GT1749VB is the turbocharger that comes standard on the ARL engine. So, what's the point of asking if the exhaust side fits?
Zak1976
Post25-03-2006, 19:59    Subject: Urgent: Differences between GT1749VA and GT1749VB exhaust side Quote
Okay, I understand. I drive an ARL, and I'm wondering if I could get a ready-made turbocharger. However, it's a combination of a GT1749VA (on the exhaust side) and a GT2052V (on the compressor side), which is why I'm asking what's different about the VA model. I want to make sure that the exhaust manifold from the VA model will fit on my ARL. According to my research, as I mentioned, the compressor's outlet and inlet are different for the VA model. Unfortunately, I don't know if there are any differences on the exhaust side. VW also couldn't provide that information, but they told me that, according to the electronic parts catalog (ETK), different gaskets are required on the exhaust side.
This topic is locked, you cannot edit or reply. Oil Leak: AFN/Turbo Exhaust Problems Diesel Engine Technology
This topic is locked, you cannot edit or reply. AFN with GT1749VB turbocharger on Audi A4 B5 Diesel Engine Technology
No new posts KP39B to GT1749VB Turbocharger Swap: Results Diesel Engine Technology
No new posts GT1749VB: Oil Pressure Pipe for Turbocharger. Diesel Engine Technology
