Adapter
jaceko
Post04-10-2002, 19:35    Subject: Adapter Quote
I want to build an adapter and I already have three circuit diagrams from Reiner's website. Which one is the latest? Which one should I build? Despite discussions in the forum, the R3 value has not been changed.
Post04-10-2002, 19:50    Subject: Adapter confusion Quote
Hi.
Sorry, but you've icon_redface.gif entered a kind of development phase with a field trial conducted by forum participants.
Version 2.0 is the most reliable option.
The issue with R3 should be resolved by replacing the diode D6; however, as a precaution, you can also use 1.8k or 1.5k resistors - although this will put a slightly higher load on the PC, but not critically, meaning it's unlikely to cause any imminent failures.
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts USB Diagnostic Adapter: Access Engine Control Unit On-Board Diagnostics (OBD)
No new posts USB K-Line Adapter: Buy Now! Diesel Engine Technology
No new posts OBD2 adapter Diesel Engine Technology
No new posts Adapter for measuring return flow rates Diesel Engine Technology
