ECU Not Available: Troubleshooting & Solutions
Opferich
Avatar-Opferich
Post23-04-2006, 11:42    Subject: ECU Not Available: Troubleshooting & Solutions Quote
Hello, I'm not able to access all control units with my diagnostic cable (Key-USB Dual-K).
"The combination instrument and comfort control unit are not responding. I can access the engine control unit and ABS. My car is a G3 Variant (GRA, window lifters, central locking) MBK ALE. I've used the search function but haven't found anything."
Use VCDS (formerly VAG-COM) 5124.
Michael.
Translated on 23-09-2026, 1:16.
Post23-04-2006, 11:58    Subject: ECU Not Available: Troubleshooting & Solutions Quote
The AI system in the G3 is not connected to the diagnostic system at all. Furthermore, the G3 doesn't even have a comfort control unit.
Guste.
Translated on 23-09-2026, 1:17.
Opferich
Avatar-Opferich
Post23-04-2006, 12:04    Subject: ECU Not Available: Troubleshooting & Solutions Quote
Thank you.
No new posts EDC15: Updateable Engine Control Unit Software Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF not regenerating Troubleshooting & Guides
No new posts CR-TDI V6 2.7L: Adjustment Channels Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A7 4K: Control units unreachable & data bus errors On-Board Diagnostics (OBD)
No new posts Control units not responding, Audi A6 2.5 TDI (solved) On-Board Diagnostics (OBD)
No new posts Control units not responding... Polo 9N AXR 2002 On-Board Diagnostics (OBD)
No new posts MicroCAN: Golf 6 - Control Units Not Responding On-Board Diagnostics (OBD)
